Pi-Hole should be receiving DNS requests from my Windows 10 laptop and therefore filtering ads. Pi-Hole was configured to be my primary DNS on this device only, not the entire network.
No ads are being blocked, and there are only 5 DNS requests from my laptop in the query log. It seems like all of these requests were made when the PC was booted up.
Also probably worth noting, the pi is connected to an ASRock router, which is connected to the main Xfinity router in my house. The reason I'm trying to configure the pi-hole on this router is because I am almost always connected to it since its so much faster.
Yep that's the static IP I assigned to it. Also can SSH just fine from my laptop. Could it have to do with the configuration of my routers?
I followed the same setup procedure on my main Xfinity router and it worked fine, but only if I was connected to that router. I wanted to see if I could make it work off of the second router since that network is so much faster.
Ok weird update, I was looking through the query on the admin panel and noticed that it blocked 3 requests for quantcount.com from my computer. I tried to connect to that URL and it blocked it, came up on the query and everything.
So it processed this request, but not any others made while browsing over the last day.
I don't see anything in the manual, I'm trying to login to the routers control panel but no one remembers they changed the password to. Probably going to have to reset it when I can
