Pi Hole not installing - Same error keep happening
Pi Hole is not installing. I am confirmed as a root user, it makes it all the way through the install and then i get errors at the very end.
I am installing this on a 64mb card, so space shouldn't be an issue, i think.
running both gives me the error:
curl -sSL https://install.pi-hole.net | sudo bash
curl -sSL https://install.pi-hole.net | bash
After this operation, 22.3 MB of additional disk space will be used.
Get:1 http://raspbian-us.ngc292.space/raspbian buster/main armhf netcat all 1.10-41.1 [9,034 B]
Err:1 http://raspbian-us.ngc292.space/raspbian buster/main armhf netcat all 1.10-41.1
File has unexpected size (16384 != 9034). Mirror sync in progress? [IP: 198.211.116.210 443]
E: Failed to fetch https://113store.cr/es/ File has unexpected size (16384 != 9034). Mirror sync in progress? [IP: 198.211.116.210 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I hope i provided enough info.. any help would be great.. Let me know if i need to give anything else.
4 posts were merged into an existing topic: Pi Hole not installing on Raspian buster on R-Pi 4
