Pi hole not blocking TXT records with regex filters
Record types other than A/AAAA are also blocked when they match a regex filter
TXT records are being forwarded to the upstream DNS provider
Excerpt from /var/log/pihole-FTL.log
[2020-01-28 14:05:02.596 17213] Regex in line 2 "sophosxl\.net$" matches "qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net"
[2020-01-28 14:05:02.600 17213] Added qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net to cache
[2020-01-28 14:05:02.600 17213] **** forwarded qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net to 1.0.0.1 (ID 61, dnsmasq/forward.c:558)
[2020-01-28 14:05:02.601 17213] **** forwarded qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net to 1.1.1.1 (ID 61, dnsmasq/forward.c:558)
And the corresponding row in the UI is:
2020-01-28 14:05:02 	TXT	qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net	192.168.42.103	OK (forwarded)	N/A
Upstream doesn't reply with response, not sure if that should make any difference. These queries are actually used to send data to a service rather than to look up a name.
$ dig TXT @1.1.1.1 qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net
; <<>> DiG 9.10.6 <<>> TXT @1.1.1.1 qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 54763
; EDNS: version: 0, flags:; udp: 1452
;qvfpbhefr.cv-ubyr.arg.w.00.a.sophosxl.net. IN TXT
;; Query time: 37 msec
;; SERVER: 1.1.1.1#53(1.1.1.1)
;; WHEN: Tue Jan 28 14:17:41 GMT 2020
;; MSG SIZE  rcvd: 70
see here, no longer a problem in beta5, apparently (not yet tested).
As noted above, this is not the expected behavior in V4.x.
Ah, thank you all for the info
-Gordon
also mentioned here (topic already closed, so no update)
The current `development` version already blocks all types of requests so you won’t need to do anything in addition.
FTL v4.x blocks only `A` and `AAAA`
I've been running Beta5 for a couple of days now, and can confirm pihole-FTL now blocks all types of requests (no SURICATA alerts anymore).
