I have no idea why it is not working now
nslookup flurry.com
Server: UnKnown
Address: fe80::deef:9ff:fef2:60d6
Non-authoritative answer:
Addresses: 212.82.100.153
98.136.103.26
74.6.136.153
nslookup flurry.com
Server: UnKnown
98.136.103.26
74.6.136.153
That's strange ... I have a Nighthawk R9000 myself and that's how I have it set-up and it works.
One thing you could do (as you don't really need it within your LAN), is disable IPV6 ...
While I understand the need for it (as a whole), I think that if one doesn't have a solid IPV6 understanding, it causes more issues than good.
R6400 here you want to use the link local fe80
Yes ipv6 is a bit complex
Link locals can bind per interface. If you really need IPv6, and you don't in most cases, then go with a LUA. But really unless you have an absolute need for IPv6 then just disable it and save the headache.
I can not find the option to disable IPv6 where should I be looking?
n.v.m I'm blind
And sorry, that's ULA not LUA.
See ignorance I can't keep all of the address names straight LOL
So I disabled the IPv6 on my netgear but when I do nslookup flurry.com
Server: UnKnown
Addresses: 98.136.103.26
212.82.100.153
74.6.136.153
I still show IPv6 wtf?
It's cached.
Do a release/renew and disable IPV6 on the client also
I did ipconfig /release and renew still does it
Did you remove the DNS v6 from the router and reboot
Yes can't hurt
Never mind now it just uses IPv4 nslookup flurry.com
Server: UnKnown
Address: 192.168.1.2
74.6.136.153
98.136.103.26
when I go incognito I still get ads
I just get alot of google DNS server
Is that whom you've selected for DNS?
yes Indeed
Well from above it appears you are using your router for dns 192.168.1.2?
