What I have setup is Pi-hole followed the basic setup after that I disabled DHCP on my router and enabled DHCP on my Pi-hole all my clients are receiving Pi-hole as DNS but I does not seem to block very many advertisements? tried to generate a debug token but got stuck at dashboard and block page
*** [ INITIALIZING ]
[i] 2019-10-24:13:00:30 debug log has been initialized.
[i] Core: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-ge41c4b5
[i] Web: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-g38d8e77
[✓] FTL: v4.3.1
[i] 1.4.53
[i] 7.3.9
[✓] Raspbian GNU/Linux 10 (buster)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv6l
[✓] IPv4 address(es) bound to the wlan0 interface:
192.168.1.13/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the wlan0 interface:
2002:c0a8:b20b::4 matches the IP found in /etc/pihole/setupVars.conf
fe80::144b:2b20:6659:d473 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.1.1...
[✓] Gateway responded.
[i] Default IPv6 gateway: fe80::deef:9ff:fef2:60d6
* Pinging fe80::deef:9ff:fef2:60d6...
ping6: Warning: source address might be selected on device other than wlan0.
[*:80] is in use by lighttpd
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[*:53] is in use by pihole-FTL
[127.0.0.1:4711] is in use by pihole-FTL
[[::1]:4711] is in use by pihole-FTL
[✓] bs.serving-sys.com.20558.9120.302br.net is 0.0.0.0 via localhost (127.0.0.1)
[✓] bs.serving-sys.com.20558.9120.302br.net is 0.0.0.0 via Pi-hole (192.168.1.13)
[✓] doubleclick.com is 172.217.20.110 via a remote, public DNS server (8.8.8.8)
[✓] 2mycomputer.com is :: via localhost (::1)
[✓] 2mycomputer.com is :: via Pi-hole (2002:c0a8:b20b::4)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=wlan0
IPV4_ADDRESS=192.168.1.13/24
IPV6_ADDRESS=2002:c0a8:b20b::4
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
BLOCKING_ENABLED=true
DHCP_ACTIVE=true
DHCP_START=192.168.1.1
DHCP_END=192.168.1.251
DHCP_ROUTER=192.168.1.1
DHCP_LEASETIME=24
PIHOLE_DOMAIN=lan
DHCP_IPv6=true
DHCP_rapid_commit=false
Addresses: ::
0.0.0.0
But I did change my IPv6 locally but I want to use my DHCP server on the Pi-hole to distribute the IPv6 DNS why does this not work?
