tourili
November 27, 2022, 5:44am
1
Hello
i have Pi Hole installed on my ubuntu 20.4. On my phone it seems to work fine, but not so much on my pc win 11.
I did the test with the Pi-Hole Ad Tester – Fuzz The Pi Guy . On my phone no ads are showing, but on my PC it does show the ads I tried Chrome and Edge
Need your help please as i am investigating this issue since few days now, and here is the debug token : https://tricorder.pi-hole.net/G8NhvvE5/
Thanks a lot
jfb
November 28, 2022, 1:33am
2
From a client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
nslookup pi.hole
nslookup flurry.com
nslookup flurry.com 192.168.1.19
tourili
November 28, 2022, 2:41am
3
Hi jfb.
here ar ethe output
nslookup pi.hole:
Server: pi.hole
Address: 192.168.1.19
Addresses: fe80::d694:476a:9ffd:ed25
192.168.1.19
nslookup flurry.com
Server: pi.hole
Non-authoritative answer:
Addresses: 74.6.136.150
98.136.103.23
212.82.100.150
Server: pi.hole
Addresses: 212.82.100.150
74.6.136.150
98.136.103.23
Thanks for your help
tourili
November 30, 2022, 3:41am
4
Hello
I am not sure if those results are confirming a good setup or not ?
Should I have a 0.0.0.0 when nslookup flurry.com?
Thanks
jfb
November 30, 2022, 6:39am
5
You should receive the NULL reply (0.0.0.0) for flurry.com, since it is on almost every blocklist.
tourili
November 30, 2022, 2:02pm
6
Thanks jfb for the reply
Having the debug token https://tricorder.pi-hole.net/G8NhvvE5/ , do you think something wrong with my setup ? I am trying to investigate but I'm kind of lost a little her
Thank you so much
That's the same token from your original post as of four days ago.
Note that debug logs auto-expire after 48 hours.
Please povide a new token.
OK @Bucking_Horn , I didnt know that and actually I saw it now when egenrating the token
Thanks for letting me know
Here is my new fresh debug token https://tricorder.pi-hole.net/l6Dhnf3H/
system
Closed
December 23, 2022, 1:52pm
9
