Site which is in blocklist is not blocked on PC. When I open the same site on android phone it is blocked.
When I first open a site that is blocked on my PC, then it says "server not found" and after a few seconds it will still load the site. On android phone it's says the same thing but doesn't load the site even when refreshing.
https://tricorder.pi-hole.net/gcdr27jnsn
It worked perfectly yesterday, not sure what happened today. I even did full format and reinstall on the SD-CARD but it didn't fix the issue.
I've set pi-hole IP as primary & secondary IP in router for DNS.
I think the issue might be IPv6, but not sure about that.
ipconfig on PC:
Wireless LAN adapter Wi-Fi:
IPv6 Address. . . . . . . . . . . : 2001:1530:1001:8a4e:6dae:8b47:ac60:d09e(Preferred)
IPv6 Address. . . . . . . . . . . : 2001:1530:1001:8a4e:8811:963c:8246:3(Preferred)
IPv6 Address. . . . . . . . . . . : fd88:1196:3c82:4600:6dae:8b47:ac60:d09e(Preferred)
Temporary IPv6 Address. . . . . . : 2001:1530:1001:8a4e:d5d8:4a9f:c527:3455(Preferred)
Temporary IPv6 Address. . . . . . : fd88:1196:3c82:4600:880f:c8c1:e865:320b(Preferred)
Link-local IPv6 Address . . . . . : fe80::6dae:8b47:ac60:d09e%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.145(Preferred)
Default Gateway . . . . . . . . . : fe80::8a11:96ff:fe3c:8246%8
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : fe80::8a11:96ff:fe3c:8246%8
192.168.1.140
NetBIOS over Tcpip. . . . . . . . : Disabled
on PC:
nslookup pi.hole
Server: homerouter.cpe
Address: fe80::8a11:96ff:fe3c:8246
*** homerouter.cpe can't find pi.hole: Non-existent domain
on PC:
nslookup 192.168.1.140
Address: 192.168.1.140
on PI:
nslookup pi.hole
Server: 127.0.0.1
Address: 127.0.0.1#53
Address: fd88:1196:3c82:4600:497a:7de1:239e:552f
on PC:
nslookup doubleclick.com
Non-authoritative answer:
Addresses: 2a00:1450:400f:808::200e
216.58.211.142
on PC:
nslookup doubleclick.com 192.168.1.140
Server: Neuma
Addresses: ::
0.0.0.0
on PI:
pihole -q doubleclick.com
[i] Over 100 results found for doubleclick.com
cat /etc/resolv.conf
nameserver 127.0.0.1
