Hi guys, sorry for posting another topic about this, but since none of what i found resolved my problem, here it goes.
I have a ARM board that is currently running armbian 22.08 and the pi-hole is running in a docker container.
Some acknowledges to help us find the problem:
- The board is connected to the router and it's IP is
192.168.1.80. - The router is currently configured as the following:
- The docker-compose.yaml is setup as the following:
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp"
- "80:80/tcp"
- "443:443/tcp"
environment:
TZ: 'Europe/Lisbon'
FTLCONF_LOCAL_IPV4: 192.168.1.80
volumes:
- './etc-pihole/:/etc/pihole/'
- './etc-dnsmasq.d/:/etc/dnsmasq.d/'
dns:
- 127.0.0.1
- 1.1.1.1
cap_add:
- NET_ADMIN
restart: unless-stopped
- I didn't change any DNS configuration in any of my devices (so it can be setup for what's defined on the router)
- ipconfig /all:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
IPv6 Address. . . . . . . . . . . : 2001:8a0:e406:6d01:526a:3bf7:79e5:fbe6(Preferred)
Temporary IPv6 Address. . . . . . : 2001:8a0:e406:6d01:30a0:9d9a:3e94:e8a5(Preferred)
Temporary IPv6 Address. . . . . . : 2001:8a0:e406:6d01:d12c:9f1b:c976:52bb(Deprecated)
Link-local IPv6 Address . . . . . : fe80::aa3a:2f0d:d5a6:af2f%27(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.67(Preferred)
Default Gateway . . . . . . . . . : fe80::c6ea:1dff:fe6a:4754%27
192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 330329791
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-72-39-1D-B0-6E-BF-CD-53-E0
DNS Servers . . . . . . . . . . . : fe80::c6ea:1dff:fe6a:4754%27
192.168.1.254
192.168.1.80
- /etc/resolv.conf on ARM board (outside container)
# Generated by NetworkManager
search lan
nameserver 192.168.1.254
nameserver 192.168.1.80
nameserver fe80::c6ea:1dff:fe6a:4754%eth0
- /etc/resolv.conf on container
search lan
nameserver 127.0.0.11
options ndots:0
After setting the whole environment, I went to test if pi-hole was working properly using these websites:
The result was not what I was expecting since the queries appeared on pi-hole as been blocked but I still got the ads on both websites.
I also performed the debug log and it can be found here: https://tricorder.pi-hole.net/U86zaiXL/
I don't know if this is too much information or if we need more to get to the solution.
Hope I followed the forum guidelines and sorry if I miss something since I'm new here.
Best Regards,
Jorge Moreira
