Pi-hole not blocking ads but active
I installed Pi-hole on my raspberry Pi 3, set my router's only DNS option to be the raspberry pi's ip4 and ip6 address. Also tried setting my computer network settings to use the raspberry pi's ipv4 address as its DNS and that doesn't work either. On the admin page it shows the number of queries occurring but the number blocked remains 0 and I continue to have ads.
Pi-hole blocking all ads
Pi-hole receiving queries and showing connected clients but not blocking anything
Installer log
  [i] Existing PHP installation detected : PHP version 5.6.40-0+deb8u6
  [i] Reconfigure option selected
  [✓] Disk space check
  [✓] Checking apt-get for upgraded packages... 1 updates available
  [i] It is recommended to update your OS after installing the Pi-hole!
  [✓] Checking for apt-utils
  [✓] Checking for dialog
  [✓] Checking for debconf
  [✓] Checking for dhcpcd5
  [✓] Checking for git
  [✓] Checking for iproute2
  [✓] Checking for whiptail
  [i] Using Google (ECS)
  [i] Static IP already configured
  [i] Found IPv6 GUA address, using it for blocking IPv6 ads
  [i] IPv4 address: 192.168.1.2/24
  [i] IPv6 address: 2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca
  [i] Web Interface On
  [i] Web Server On
  [i] Logging On.
  [i] Privacy level 0  [i] Performing reconfiguration, skipping download of local repos
  [✓] Resetting repository within /etc/.pihole...
  [✓] Resetting repository within /var/www/html/admin...
  [i] Main Dependency checks...
  [✓] Checking for cron
  [✓] Checking for curl
  [✓] Checking for dnsutils
  [✓] Checking for iputils-ping
  [✓] Checking for lsof
  [✓] Checking for netcat
  [✓] Checking for psmisc
  [✓] Checking for sudo
  [✓] Checking for unzip
  [✓] Checking for wget
  [✓] Checking for idn2
  [✓] Checking for sqlite3
  [✓] Checking for libcap2-bin
  [✓] Checking for resolvconf
  [✓] Checking for lighttpd
  [✓] Checking for php5-common
  [✓] Checking for php5-cgi
  [✓] Checking for php5-sqlite
  [✓] Enabling lighttpd service to start on reboot...
  [i] FTL Checks...
  [✓] Detected ARM-hf architecture (armv7+)
  [i] Latest FTL Binary already installed (v4.3.1). Confirming Checksum...
  [i] Checksum correct. No need to download!
  [✓] Installing scripts from /etc/.pihole
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
  [i] Installing blocking page...
  [✓] Creating directory for blocking page, and copying files
  [✗] Backing up index.lighttpd.html
  [✓] Installing sudoer file
  [✓] Installing latest Cron script
  [✓] Installing latest logrotate script
  [i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
  [i] Skipping firewall configuration
  [✓] man pages installed and database updated
  [i] Testing if systemd-resolved is enabled
  [i] Systemd-resolved is not enabled
  [✓] Restarting lighttpd service...
  [i] Restarting services...
  [✓] Enabling pihole-FTL service to start on reboot...
  [✓] Restarting pihole-FTL service...
  [✓] Deleting existing list cache
  [i] Target: raw.githubusercontent.com (hosts)
  [i] Target: mirror1.malwaredomains.com (justdomains)
  [i] Target: sysctl.org (hosts)
  [i] Target: s3.amazonaws.com (simple_tracking.txt)
  [i] Target: s3.amazonaws.com (simple_ad.txt)
  [✓] Consolidating blocklists
  [✓] Extracting domains from blocklists
  [i] Number of domains being pulled in by gravity: 135667
  [✓] Removing duplicate domains
  [i] Number of unique domains trapped in the Event Horizon: 113448
  [i] Number of whitelisted domains: 0
  [i] Number of blacklisted domains: 0
  [i] Number of regex filters: 0
  [✓] Parsing domains into hosts format
  [✓] Cleaning up stray matter
  [✓] Force-reloading DNS service
  [✓] DNS service is running
  [i] View the web interface at http://pi.hole/admin or http://192.168.1.2/admin
  [i] You may now configure your devices to use the Pi-hole as their DNS server
  [i] Pi-hole DNS (IPv4): 192.168.1.2
  [i] Pi-hole DNS (IPv6): 2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca
  [i] If you set a new IP address, please restart the server running the Pi-hole
  [i] The install log is located at: /etc/pihole/install.log
Installation Complete!
pi@raspberrypi:~ $ pihole -d
*** [ INITIALIZING ]
[i] 2019-10-14:20:02:28 debug log has been initialized.
[i] Core: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-ge41c4b5
[i] Web: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-g38d8e77
[✓] FTL: v4.3.1
[i] 1.4.35
[i] 5.6.40
[✓] Raspbian GNU/Linux 8 (jessie)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
   192.168.1.2/24 matches the IP found in /etc/pihole/setupVars.conf
   2600:6c44:c7f:ffe2:0:eba7:6033:5943 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca matches the IP found in /etc/pihole/setupVars.conf
   fe80::8026:cd5d:a3da:6947 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   * Pinging 192.168.1.1...
[✓] Gateway responded.
[i] Default IPv6 gateway: fe80::5a90:43ff:fee0:7a50
   * Pinging fe80::5a90:43ff:fee0:7a50...
[::1]:631 cupsd (IPv6)
127.0.0.1:631 cupsd (IPv4)
*:5900 vncserver- (IPv6)
*:5900 vncserver- (IPv4)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:6001 Xvnc-core (IPv6)
*:6001 Xvnc-core (IPv4)
*:5901 Xvnc-core (IPv6)
*:5901 Xvnc-core (IPv4)
[*:80] is in use by lighttpd
[*:53] is in use by pihole-FTL
[127.0.0.1:4711] is in use by pihole-FTL
[[::1]:4711] is in use by pihole-FTL
[✓] atdmt.com.46618.9304.302br.net is 0.0.0.0 via localhost (127.0.0.1)
[✓] atdmt.com.46618.9304.302br.net is 0.0.0.0 via Pi-hole (192.168.1.2)
[✓] doubleclick.com is 172.217.8.206 via a remote, public DNS server (8.8.8.8)
[✓] analsexhard.com is :: via localhost (::1)
[✓] analsexhard.com is :: via Pi-hole (2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca)
[✓] doubleclick.com is 2607:f8b0:4009:816::200e via a remote, public DNS server (2001:4860:4860::8888)
[✓] lighttpd daemon is active
    BLOCKING_ENABLED=true
    DHCP_ACTIVE=true
    DHCP_START=192.168.1.201
    DHCP_END=192.168.1.251
    DHCP_ROUTER=192.168.1.1
    DHCP_LEASETIME=24
    PIHOLE_DOMAIN=lan
    DHCP_IPv6=false
    DHCP_rapid_commit=false
    PIHOLE_INTERFACE=eth0
    IPV4_ADDRESS=192.168.1.2/24
    IPV6_ADDRESS=2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca
    PIHOLE_DNS_1=8.8.8.8
    PIHOLE_DNS_2=8.8.4.4
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=true
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 2654708 Oct 14 19:59 /etc/pihole/gravity.list
   0.0.0.0
   0.nextyourcontent.com
   0.r.msn.com
   0.start.bz
   zzz.clickbank.net
   zzzezeroe.fr
   zzzpooeaz-france.com
   zzzrtrcm2.com
-rw-r--r-- 1 root root 313 Oct 14 19:58 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 0 Oct 14 19:04 /etc/pihole/blacklist.txt
-rw-r--r-- 1 root root 142 Oct 14 19:59 /etc/pihole/local.list
   192.168.1.2 raspberrypi
   2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca raspberrypi
   192.168.1.2 pi.hole
   2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca pi.hole
-rw-r--r-- 1 root root 234 Oct 14 19:58 /etc/pihole/logrotate
   /var/log/pihole.log {
   	su root root
   	daily
   	copytruncate
   	rotate 5
   	compress
   	delaycompress
   	notifempty
   	nomail
   /var/log/pihole-FTL.log {
   	su root root
   	weekly
   	copytruncate
   	rotate 3
   	compress
   	delaycompress
   	notifempty
   	nomail
-rw-r--r-- 1 root root 0 Oct 14 19:04 /etc/pihole/whitelist.txt
-rw-r--r-- 1 root root 1387 Oct 14 19:58 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries
   local-ttl=2
   log-async
   server=8.8.8.8
   server=8.8.4.4
   interface=eth0
-rw-r--r-- 1 root root 483 Oct 14 19:58 /etc/dnsmasq.d/02-pihole-dhcp.conf
   dhcp-authoritative
   dhcp-range=192.168.1.201,192.168.1.251,24h
   dhcp-option=option:router,192.168.1.1
   dhcp-leasefile=/etc/pihole/dhcp.leases
   domain=lan
-rw-r--r-- 1 root root 3499 Oct 14 19:58 /etc/lighttpd/lighttpd.conf
   server.modules = (
   	"mod_access",
   	"mod_accesslog",
   	"mod_auth",
   	"mod_expire",
   	"mod_compress",
   	"mod_redirect",
   	"mod_setenv",
   	"mod_rewrite"
   server.error-handler-404    = "/pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   mimetype.assign   = ( ".png"  => "image/png",
                         ".jpg"  => "image/jpeg",
                         ".jpeg" => "image/jpeg",
                         ".html" => "text/html",
                         ".js" => "application/javascript",
                         ".json" => "application/json",
                         ".txt"  => "text/plain",
                         ".svg"  => "image/svg+xml" )
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1703 Oct 14 19:58 /etc/cron.d/pihole
   4 4   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   18 17  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 1791 Oct 14 19:58 /var/log/lighttpd/error.log
   2019-10-14 00:47:51: (log.c.164) server started
   2019-10-14 00:48:18: (server.c.1558) server stopped by UID = 0 PID = 1
   2019-10-14 00:48:19: (log.c.164) server started
   2019-10-14 00:48:19: (server.c.1045) WARNING: unknown config-key: alias.url (ignored)
   2019-10-14 00:50:33: (server.c.1558) server stopped by UID = 0 PID = 1
   2019-10-14 00:50:38: (log.c.164) server started
   2019-10-14 00:50:38: (server.c.1045) WARNING: unknown config-key: alias.url (ignored)
   2019-10-14 18:34:43: https://dts.innovid.com/clktru/action/vclk?project_hash=1hcbsl&client_id=3997&video_id=485798&channel_id=1537374&publisher_id=888&placement_tag_id=0&project_state=2&r=1571096067036&placement_hash=1mn4e4&device_id=&action=clktru&click=https%3A%2F%2Fad.doubleclick.net%2Fddm%2Ftrackclk%2FN6344.646586TWITCHINTERACTIVEINC%2FB22910919.256721375%3Bdc_trk_aid%3D453033586%3Bdc_trk_cid%3D99808761%3Bdc_lat%3D%3Bdc_rdid%3D%3Btag_for_child_directed_treatment%3D%3Btfua%3D&ivc_exdata= is not a valid domain
   2019-10-14 18:54:46: (server.c.1558) server stopped by UID = 0 PID = 1
   2019-10-14 18:54:51: (log.c.164) server started
   2019-10-14 18:54:51: (server.c.1045) WARNING: unknown config-key: alias.url (ignored)
   2019-10-14 19:55:15: (server.c.1558) server stopped by UID = 0 PID = 1
   2019-10-14 19:55:15: (log.c.164) server started
   2019-10-14 19:55:15: (server.c.1045) WARNING: unknown config-key: alias.url (ignored)
   2019-10-14 19:58:40: (server.c.1558) server stopped by UID = 0 PID = 1
   2019-10-14 19:58:41: (log.c.164) server started
   2019-10-14 19:58:41: (server.c.1045) WARNING: unknown config-key: alias.url (ignored)
-rw-r--r-- 1 pihole pihole 31805 Oct 14 19:59 /var/log/pihole-FTL.log
   [2019-10-14 00:48:31.183 8390] Using log file /var/log/pihole-FTL.log
   [2019-10-14 00:48:31.183 8390] ########## FTL started! ##########
   [2019-10-14 00:48:31.183 8390] FTL branch: master
   [2019-10-14 00:48:31.183 8390] FTL version: v4.3.1
   [2019-10-14 00:48:31.183 8390] FTL commit: b60d63f
   [2019-10-14 00:48:31.183 8390] FTL date: 2019-05-25 21:37:26 +0200
   [2019-10-14 00:48:31.183 8390] FTL user: pihole
   [2019-10-14 00:48:31.183 8390] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
   [2019-10-14 00:48:31.184 8390]    SOCKET_LISTENING: only local
   [2019-10-14 00:48:31.184 8390]    AAAA_QUERY_ANALYSIS: Show AAAA queries
   [2019-10-14 00:48:31.184 8390]    MAXDBDAYS: max age for stored queries is 365 days
   [2019-10-14 00:48:31.184 8390]    RESOLVE_IPV6: Resolve IPv6 addresses
   [2019-10-14 00:48:31.184 8390]    RESOLVE_IPV4: Resolve IPv4 addresses
   [2019-10-14 00:48:31.184 8390]    DBINTERVAL: saving to DB file every minute
   [2019-10-14 00:48:31.184 8390]    DBFILE: Using /etc/pihole/pihole-FTL.db
   [2019-10-14 00:48:31.184 8390]    MAXLOGAGE: Importing up to 24.0 hours of log data
   [2019-10-14 00:48:31.184 8390]    PRIVACYLEVEL: Set to 0
   [2019-10-14 00:48:31.184 8390]    IGNORE_LOCALHOST: Show queries from localhost
   [2019-10-14 00:48:31.184 8390]    BLOCKINGMODE: Null IPs for blocked domains
   [2019-10-14 00:48:31.184 8390]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
   [2019-10-14 00:48:31.184 8390]    DBIMPORT: Importing history from database
   [2019-10-14 00:48:31.184 8390]    PIDFILE: Using /var/run/pihole-FTL.pid
   [2019-10-14 00:48:31.184 8390]    PORTFILE: Using /var/run/pihole-FTL.port
   [2019-10-14 00:48:31.185 8390]    SOCKETFILE: Using /var/run/pihole/FTL.sock
   [2019-10-14 00:48:31.185 8390]    WHITELISTFILE: Using /etc/pihole/whitelist.txt
   [2019-10-14 00:48:31.185 8390]    BLACKLISTFILE: Using /etc/pihole/black.list
   [2019-10-14 00:48:31.185 8390]    GRAVITYFILE: Using /etc/pihole/gravity.list
   [2019-10-14 00:48:31.185 8390]    REGEXLISTFILE: Using /etc/pihole/regex.list
   [2019-10-14 00:48:31.185 8390]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
   [2019-10-14 00:48:31.185 8390]    AUDITLISTFILE: Using /etc/pihole/auditlog.list
   [2019-10-14 00:48:31.185 8390]    MACVENDORDB: Using /etc/pihole/macvendor.db
   [2019-10-14 00:48:31.185 8390]    PARSE_ARP_CACHE: Active
   [2019-10-14 00:48:31.185 8390] Finished config file parsing
   [2019-10-14 00:48:31.186 8390] SQLite3 message: cannot open file at line 38452 of [0eca3dd3d3] (14)
   [2019-10-14 00:48:31.186 8390] SQLite3 message: os_unix.c:38452: (2) open(/etc/pihole/pihole-FTL.db) -  (14)
   [2019-10-14 19:58:44.626 6965]    GRAVITYFILE: Using /etc/pihole/gravity.list
   [2019-10-14 19:58:44.626 6965]    REGEXLISTFILE: Using /etc/pihole/regex.list
   [2019-10-14 19:58:44.626 6965]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
   [2019-10-14 19:58:44.626 6965]    AUDITLISTFILE: Using /etc/pihole/auditlog.list
   [2019-10-14 19:58:44.626 6965]    MACVENDORDB: Using /etc/pihole/macvendor.db
   [2019-10-14 19:58:44.626 6965]    PARSE_ARP_CACHE: Active
   [2019-10-14 19:58:44.626 6965] Finished config file parsing
   [2019-10-14 19:58:44.628 6965] Database version is 3
   [2019-10-14 19:58:44.628 6965] Database successfully initialized
   [2019-10-14 19:58:44.629 6965] New forward server: 8.8.4.4 (0/512)
   [2019-10-14 19:58:44.629 6965] New forward server: 8.8.8.8 (1/512)
   [2019-10-14 19:58:44.643 6965] Imported 2242 queries from the long-term database
   [2019-10-14 19:58:44.644 6965]  -> Total DNS queries: 2242
   [2019-10-14 19:58:44.644 6965]  -> Cached DNS queries: 46
   [2019-10-14 19:58:44.644 6965]  -> Forwarded DNS queries: 2184
   [2019-10-14 19:58:44.644 6965]  -> Exactly blocked DNS queries: 0
   [2019-10-14 19:58:44.644 6965]  -> Unknown DNS queries: 12
   [2019-10-14 19:58:44.644 6965]  -> Unique domains: 32
   [2019-10-14 19:58:44.644 6965]  -> Unique clients: 3
   [2019-10-14 19:58:44.644 6965]  -> Known forward destinations: 2
   [2019-10-14 19:58:44.644 6965] Successfully accessed setupVars.conf
   [2019-10-14 19:58:44.672 6967] PID of FTL process: 6967
   [2019-10-14 19:58:44.672 6967] Listening on port 4711 for incoming IPv4 telnet connections
   [2019-10-14 19:58:44.672 6967] Listening on port 4711 for incoming IPv6 telnet connections
   [2019-10-14 19:58:44.672 6967] Listening on Unix socket
   [2019-10-14 19:58:44.674 6967] Received SIGHUP, reloading cache
   [2019-10-14 19:58:44.674 6967] Blocking status is enabled
   [2019-10-14 19:58:44.674 6967] Compiled 0 Regex filters and 0 whitelisted domains in 0.1 msec (0 errors)
   [2019-10-14 19:58:44.675 6967] /etc/pihole/black.list: parsed 0 domains (took 0.1 ms)
   [2019-10-14 19:58:46.118 6967] /etc/pihole/gravity.list: parsed 113448 domains (took 1443.0 ms)
   [2019-10-14 19:59:54.897 6967] Received SIGHUP, reloading cache
   [2019-10-14 19:59:54.897 6967] Blocking status is enabled
   [2019-10-14 19:59:54.897 6967] Compiled 0 Regex filters and 0 whitelisted domains in 0.1 msec (0 errors)
   [2019-10-14 19:59:55.134 6967] /etc/pihole/black.list: parsed 0 domains (took 0.1 ms)
   [2019-10-14 19:59:56.029 6967] /etc/pihole/gravity.list: parsed 113448 domains (took 895.1 ms)
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 323584 Oct 14 19:58 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 Oct 14 19:58 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 65536 Oct 14 19:58 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 12288 Oct 14 19:58 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 28 Oct 14 19:58 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 53248 Oct 14 19:58 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 196608 Oct 14 19:59 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Oct 14 19:58 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 4096 Oct 14 19:58 /dev/shm/FTL-strings
*** [ DIAGNOSING ]: Locale
    LANG=en_GB.UTF-8
-rw-r--r-- 1 pihole pihole 546704 Oct 14 20:02 /var/log/pihole.log
   -----head of pihole.log------
   Oct 14 00:48:31 dnsmasq[8392]: started, version pi-hole-2.80 cachesize 10000
   Oct 14 00:48:31 dnsmasq[8392]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
   Oct 14 00:48:31 dnsmasq[8392]: using nameserver 8.8.4.4#53
   Oct 14 00:48:31 dnsmasq[8392]: using nameserver 8.8.8.8#53
   Oct 14 00:48:31 dnsmasq[8392]: read /etc/hosts - 5 addresses
   Oct 14 00:48:31 dnsmasq[8392]: failed to load names from /etc/pihole/local.list: No such file or directory
   Oct 14 00:48:31 dnsmasq[8392]: failed to load names from /etc/pihole/black.list: No such file or directory
   Oct 14 00:48:31 dnsmasq[8392]: failed to load names from /etc/pihole/gravity.list: No such file or directory
   Oct 14 00:48:31 dnsmasq[8392]: query[AAAA] raw.githubusercontent.com from 127.0.0.1
   Oct 14 00:48:31 dnsmasq[8392]: forwarded raw.githubusercontent.com to 8.8.4.4
   Oct 14 00:48:31 dnsmasq[8392]: forwarded raw.githubusercontent.com to 8.8.8.8
   Oct 14 00:48:31 dnsmasq[8392]: reply raw.githubusercontent.com is <CNAME>
   Oct 14 00:48:31 dnsmasq[8392]: reply github.map.fastly.net is NODATA-IPv6
   Oct 14 00:48:31 dnsmasq[8392]: query[A] raw.githubusercontent.com from 127.0.0.1
   Oct 14 00:48:31 dnsmasq[8392]: cached raw.githubusercontent.com is <CNAME>
   Oct 14 00:48:31 dnsmasq[8392]: reply github.map.fastly.net is 151.101.0.133
   Oct 14 00:48:31 dnsmasq[8392]: reply github.map.fastly.net is 151.101.64.133
   Oct 14 00:48:31 dnsmasq[8392]: reply github.map.fastly.net is 151.101.128.133
Your debug log shows that Pi-Hole is working properly. Let's look at the connectivity between the clients and Pi-Hole.
What is the output of this command from the Pi terminal:
echo ">stats" | nc localhost 4711
echo ">top-clients withzero" | nc localhost 4711
And from either the terminal or command prompt of a connected client:
nslookup pi.hole
domains_being_blocked 113448
dns_queries_today 2323
ads_blocked_today 4
ads_percentage_today 0.172191
unique_domains 39
queries_forwarded 2230
queries_cached 77
clients_ever_seen 6
unique_clients 6
dns_queries_all_types 2323
reply_NODATA 15
reply_NXDOMAIN 0
reply_CNAME 9
reply_IP 41
privacy_level 0
status enabled
---EOM---
0 2288 127.0.0.1 localhost
1 17 192.168.1.3
2 16 192.168.1.128
3 1 192.168.1.2 raspberrypi
4 1 ::1 localhost
5 1 2600:6c44:c7f:ffe2:f894:5ac6:f294:12ca raspberrypi
---EOM---
Server: 127.0.0.1
Address: 127.0.0.1#53
Address: 192.168.1.2
That last command appears to have been run from the Pi Terminal or via ssh to the terminal, not directly on a connected client.
My bad, here is from a connected client, though something seems wrong here
Server: rns01.charter.com
Address: 2607:f428:ffff:ffff::1
*** rns01.charter.com can't find pi.hole: Non-existent domain
Your debug log shows that you are using Pi-Hole as DHCP, yet the client still has the ISP DNS assigned. After you made the change to use Pi-Hole DHCP, did you renew the DHCP lease on all clients?
Also, disable IPv6 on the router if you can, since the DNS address being pushed is the IPv6 DNS.
Ok, i turned off DHCP on my pi-hole and it appears to be working now, thank you so much for your help. I forgot that while I was trouble shooting I turned that setting on and forgot to turn it back off.
It now shows that it is blocking queries but I am still getting some ads on youtube, might be cached ads from me trying so much recently.
It us difficult to block YouTube ads in Pi-Hole since ads come from subdomains of the content domains. The subdomains and content domains change regularly.
