The issue I am facing:
I've been doing some electrical work lately, and I've had to shut off the breaker that powers my Pi-hole (with Unbound installed). Every time the Pi-hole is powered off this way, it will not gracefully resume working again because, for reasons I don't fully understand, the default nameserver 127.0.0.1 in /etc/resolv.conf is preventing the Pi-hole (and thus the entire rest of my network) from accessing the Internet. Running pihole -r doesn't fix this either.
I can fix this by temporarily using Cloudflare's DNS by changing the value in /etc/resolv.conf to nameserver 1.1.1.1, and the Pi-hole begins working again instantly. It even continues to work after I sudo reboot now, even though the value in /etc/resolv.conf reverts back to 127.0.0.1.
Now I know that it's possible to change the default value of /etc/resolv.conf/ by editing /etc/dhcpcd.conf, but I've been cautioned against changing this value to something other than 127.0.0.1 because supposedly it's less secure and less efficient. Is there a way to make my Pi-hole resume gracefully after losing power without having to use an external DNS's IP here?
Here's the return value for my cat /etc/dhcpcd.conf:
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Most distributions have NTP support.
#option ntp_servers
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
# Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
interface eth0
static ip_address=192.168.122.3/24
static routers=192.168.122.1
Details about my system:
- AT&T fiber jack --> Arris BGW210 [in pass-through mode] --> AmpliFi Instant Router --> Gigabit switch -> Raspberry Pi (+ rest of network)
- Both
eth0andwlan0are connected to the router, with theeth0's static IP assigned as the router's DNS server - PiHole is also serving has the DHCP server for the Amplifi router, which has "Bypass DNS cache" option enabled
- Have set up Unbound/DNSMasq to use local DNS caching
- Have
pihole-updatelistsscript installed - Have
homebridgeinstalled on same Pihole
Debug log: https://tricorder.pi-hole.net/ekmtvrts4s
