Hello,
I've used Pi-Hole for many years without any issues, however, after doing updates to both router (Asus AC88U) and a fresh install of Pi-Hole the two are not communicating in regards to DNS queries. To clarify:
- Asus AC88U with latest firmware (3.0.0.1.386_43129)
- Raspberry Pi with Raspberry Pi OS 32bit lite.
- Pi-Hole (Pi-hole v5.3.1 Web Interface v5.5 FTL v5.8.1)
Tests:
. If I set my DNS on my PC to the LAN IP of the Pi-Hole it works.
. If I change the WAN DNS Setting on the Asus router to the LAN IP of the Raspberry Pi it doesn't. Can't resolve domains. This has always worked previously.
I don't know if the issue is the Firmware on the router (might try downgrading) or the Pi-Hole is blocking the Router. Does anyone have any suggestions on how to resolve?
Kindest regards,
Nick
