I installed pihole in my laptop(linux mint). I connect to different wifis at different places, so pihole seemed like lot of work to use. So I uninstalled pi-hole with pihole uninstall command. I thought internet would go back to normal working again.
[after uninstalling pihole my internet is not working.I cant even ping 8.8.8.8 in laptop ]
[I cant run that script now as I cant access internet. Im posting this message from mobile.]
My resolv.conf now has nameserver 127.0.0.53.
I tried changing that to 192.168.1.1 and restarting networkmanager by
systemctl restart network-manager
But it is of no use. What should i do now. Please help. This is my first time posting in a forum( sorry for mistakes). Please help me
pi@noads:~ $ apt show dhcpcd5
Description: DHCPv4, IPv6RA and DHCPv6 client with IPv4LL support
dhcpcd is a one stop network management daemon which includes
* RFC compliant DHCPv4 and DHCPv6 clients
* DHCPv6 Prefix Delegation support
* IPv4LL (aka ZeroConf) support
* ARP address conflict resolution
* Link carrier detection
* Wireless SSID profiles
* ARP ping profiles
If use network-manager to configure your network, make sure its "active":
sudo service network-manager status
Check if dhcpcd is also active which means both network managers are fighting over control:
sudo service dhcpcd status
Disable dhcpcd if active:
sudo systemctl disable dhcpcd
Reboot and check connectivity:
sudo reboot
journalctl -u networking
journalctl -u network-manager
ip l
ip a
ip r
You could remove/uninstall dhcpcd5 if have no use for it:
