The issue I am facing:
When I go to versions.pi-hole.net I am told that the server was not found by Firefox and Chrome. Chrome says "versions.pi-hole.net’s DNS address could not be found. Diagnosing the problem." and thinks there's a typo.
This is the first time I had noticed this issue, but it has probably happened before and I probably just didn't notice or assumed the website blocked my ip
I have a pi-hole installed in my network.
I have a router with OpenWRT and tor. Tor was configured following the OpenWRT tor guide + the advice on this forum post. This issue happens even without tor.
I am also using a vpn (Windscribe) on my Pi-Hole, but even when it's disconnected I have the same issue.
I think I also made a change with the Pi-Hole page. Instead of showing you the slogan, it says "warning, be careful with what you clicked!"
Details about my system:
Pi-Hole is installed in a Raspberry Pi Lite Zero right now (I was able to continue with the setup and workaround this error)
Debug log
https://tricorder.pi-hole.net/YTiCIo1E/
