It looks like Pi-hole receives request from my pc and responds to them, I can block domains (adding as wildcard to the blacklist) and it blocks them but every possible ad on the website is still shown (I have added many adlists that are getting updated and are dedicated for my country) also local dns and pi.hole work. There are queries blocked but every ad on the website is still visible the moment I turn off my browser adblocker
Details about my system:
From what I can tell IPV6 is disabled on my network completely
Proxmox:
Pi-Hole (192.168.0.6) is hosted on a Debian container, unbound (192.168.0.7) is hosted on another container (Alpine Linux) on the same network and the same proxmox node
DHCP is enabled on my router but Pi-Hole and also Unbound have ips 192.168.0.6 & 192.168.0.7 reserved permamently and added as a rule
Created a container for unbound then removed Pi-Hole container and installed it on a new one hole so technically nothing. Unbound still resolves requests - there is also wireguard on another container (Alpine Linux) that uses Pi-Hole local IP as a dns (192.168.0.6)
From what I can see the first nslookup answers with a ipv6? maybe I just don't have a public one. It never got detected and there is nothing about ipv6 in the router settings
When I disable blocking nslookup flurry.com responds with normal ip not 0.0.0.0, as I said the whole site gets blocked but any ads on site dont
DNS-over-HTTPS is disabled in my browser same in windows settings.
I'm kinda confused by how it works, I can't connect to blocked sites (from blocked domains and adlists) but yet every ad on the website is displayed. Even though I use nearly the same lists like uOrigin for example and I disable uOrigin itself every ad is displayed even though pi-hole is still turned on
You can't use lists designed for uBO with Pi-hole. uBO works fundamentally different.
As a DNS filter, Pi-hole only ever receives DNS requests. It can filter your entire network's DNS traffic, regardless which device or software is making a request.
It can either block or allow a domain. In particular, that means that Pi-hole cannot block a domain that is used to play out contents as well as ads without blocking the contents also.
uBO is a browser extension that sees the complete HTTP request, i.e. it can filter on any resource element in the path, not just the domain, but it will only ever filter requests of the very browser that it's been installed into.
Thus, using both Pi-hole and uBO side by side complements each other.
I'm not privileged to know whether that 'cnn site' would happen to include ads from flurry.com.
In general, any website linking to that domain would have that domain blocked by Pi-hole, provided Pi-hole would receive the respective DNS request, and a blocklist with that domain is active in Pi-hole, and blocking is configured correctly, where the latter two have been confirmed by your nslookup result.
