Set up remote access to the Pi by installing tightvnc and xrdp (am using mstsc.exe from Windows to access the Pi).
Turned the RPI off and on (can connect to it using the Pi-hole web interface, and mstsc.exe).
On the router: under DHCP config, I set the DNS server to 192.168.0.250
To test: disabled/enabled WiFi on my phone. It gets the correct DNS server IP: 192.168.0.250
Result/problem: NO internet access whatsoever (websites, apps) from my phone.
Things I've tried:
Using different DNS servers (Google, OpenDNS, others).
Disabling all six entries in the Blacklists.
Disabled WiFi (and Bluetooth) on the RPI.
The RPI can connect to internet just fine, open websites etc..
ran: pihole -r ("Reconfigure or Repair Pi-hole subsystems").
Search for solutions for hours, to no avail. Similar problems seems to have different, unrelated causes.
I'm barely familiar with RPI/Raspbian etc.
What can I do to find the source of this problem?
Thanks for your swift reply. In the router I just set the first DNS entry to the RPI (192.168.0.250) and the second DNS to 192.168.0.251 (that's not in use, yet I can't enter 0.0.0.0).
Then on windows renewed the lease: ipconfig /renew
On the Windows PC (ethernet connection) I DO have internet access. Didn't test that earlier (figured that if one doesn't work, no device will)...
On an iPad (with mobile data disabled) I get the correct DNS servers and DO have internet access...
The phone is an iPhone Xs. I've tried setting Mobile Data off, doesn't make a difference.
On the PC, in the browser pi.hole goes to the web interface.
On the iPhone AND iPad, pi.hole doesn't work ('can't load page').
Tried with a second iPhone (model 7): same result as the Xs, doesn't work.
Also tried a second iPad: same results as the first iPad, DOES work. So only the iPhones are not working for some reason....
On the iPad both those URLs DO work.
On the iPhone they both do NOT work.
Ahhh I know what the issue is; the iPad is connected to a WiFi that can see the local network.
The iPhones are connected to a guest network, that can ONLY go to the public internet....
All four devices can connect to both the 'local' WiFi and Guest WiFi, and as luck would have it both iPads were connected to the 'local' WiFi, the iPhones were both connected to the guest network...
Just tested this: connected an iPhone to the internal WiFi, it works now. Thanks a lot for your help.
