Pi-Hole ip address
I've recently installed pihole but for some reason it isnt working and I wanna know my Pihole DNS server address which I just cannot find
Heres the debug token
https://tricorder.pi-hole.net/FXiSSCgs/
It's usually the other way around: you tell Pi-hole host what IP should be used.
To be more specific, you need to set a static IP on your operating system (or set a static DHCP lease on your router).
This is documentation about this prerequisite:
The IP address of your Pi is: 192.168.100.114
