Hier noch die Bash-History:
pi@raspberrypi:~ $ curl -sSL https://install.pi-hole.net | bash
[✗] Root user check
Script called with non-root privileges
The Pi-hole requires elevated privileges to install and run
Please check the installer for any concerns regarding this requirement
Make sure to download this script from a trusted source
[✓] Sudo utility check
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[✓] Disk space check
[✓] Checking for apt-utils
[i] Checking for dialog (will be installed)
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[i] Checking for git (will be installed)
[✓] Checking for iproute2
[✓] Checking for whiptail
[✓] Stopping dnsmasq service...
[✓] Stopping lighttpd service...
[i] Using [✓] Set IP address to 192.168.178.58
You may need to restart after the install is complete
[i] Found IPv6 ULA address, using it for blocking IPv6 ads
[i] IPv4 address: 192.168.178.58/24
[i] IPv6 address: fd04:bd3:80e8:1:8038:46fd:53e8:4b09
[i] Web Interface On
[i] Logging On.
[✗] Check for existing repository in /etc/.pihole
[✓] Clone GitHub - pi-hole/pi-hole: A black hole for Internet advertisements into /etc/.pihole
[✗] Check for existing repository in /var/www/html/admin
[✓] Clone GitHub - pi-hole/web: Pi-hole Dashboard for stats and more into /var/www/html/admin
[i] Main Dependency checks...
[i] Checking for bc (will be installed)
[✓] Checking for cron
[✓] Checking for curl
[i] Checking for dnsmasq (will be installed)
[i] Checking for dnsutils (will be installed)
[✓] Checking for iputils-ping
[i] Checking for lsof (will be installed)
[i] Checking for netcat (will be installed)
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[i] Checking for idn2 (will be installed)
[i] Checking for sqlite3 (will be installed)
[i] Checking for lighttpd (will be installed)
[i] Checking for php5-common (will be installed)
[i] Checking for php5-cgi (will be installed)
[i] Checking for php5-sqlite (will be installed)
pi@raspberrypi:~ $ sudo apt-get update
Hit:1 Index of /debian stretch InRelease
Hit:2 Index of /raspbian stretch InRelease
Reading package lists... Done
pi@raspberrypi:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~ $ sudo apt-get autoclear
E: Invalid operation autoclear
pi@raspberrypi:~ $ sudo shutdown -r now
Connection to raspberrypi closed by remote host.
Connection to raspberrypi closed.
$ ssh -l pi raspberrypi
pi@raspberrypi's password:
Linux raspberrypi 4.14.30-v7+ #1102 SMP Mon Mar 26 16:45:49 BST 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Apr 8 13:00:12 2018 from 2003:ed:e3cc:8300:30e4:71c4:de7:b62f
Wi-Fi is disabled because the country is not set.
Use raspi-config to set the country before use.
pi@raspberrypi:~ $ hostname
raspberrypi
pi@raspberrypi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.178.58 netmask 255.255.255.0 broadcast 192.168.178.255
inet6 fd04:bd3:80e8:1:8038:46fd:53e8:4b09 prefixlen 64 scopeid 0x0
inet6 2003:ed:e3cc:8300:e7f0:bec8:9876:1b41 prefixlen 64 scopeid 0x0
inet6 fe80::2bf0:703c:113:2af6 prefixlen 64 scopeid 0x20
ether b8:27:eb:52:55:cc txqueuelen 1000 (Ethernet)
RX packets 3475 bytes 342472 (334.4 KiB)
RX errors 0 dropped 154 overruns 0 frame 0
TX packets 130 bytes 20483 (20.0 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 800 bytes 64800 (63.2 KiB)
TX packets 800 bytes 64800 (63.2 KiB)
pi@raspberrypi:~ $ pihole -h
-bash: pihole: command not found
