_eMa
August 15, 2018, 4:42pm
1
on my system :
> Description:|Debian GNU/Linux 8.11 (jessie)
my installation end on this point :
https://c2.staticflickr.com/2/1831/44053226381_a8e4351466_o.png
with -vx , the last information is :
debconf-apt-progress -- apt-get --yes --no-install-recommends install bc dnsutils netcat unzip idn2 sqlite3 dns-root-data resolvconf lighttpd php5-cgi php5-sqlite
Thank you
Please try the following steps in the following order
sudo nano /etc/resolv.conf
change whatever is in there to 9.9.9.9
save the file
re run `curl -sSL https://install.pi-hole.net | bash -vx
Based on the info you have provided it looks like the system is unable to get from apt and it also appears unable to clone the repos from GitHub. The above command should resolve this for you
_eMa
August 15, 2018, 4:50pm
3
Hi. I try with 9.9.9.9 but same problem.
Now I try to disable IPS on my router
Thank you
You can try to manually install each dependency that is missing that may help
_eMa
August 16, 2018, 7:33am
5
I try to disable IPS\Firewall on my router, but same problem.
How i can manually install each dependency that is missing ?
Thank you
system
Closed
September 6, 2018, 7:34am
6
