I just tried installing pi-hole on a R-Pi 3 running raspbian stretch using this command: curl -sSL https://install.pi-hole.net | bash
The install appeared to go fine. pi-hole is running and I can resolve domains through it. However when I bring up the dashboard in a web browser it only ever shows the spinning arrows where the graphs are supposed to be, and if I view the Query Log it never shows any results even though I've manually resolved a number of hosts against the pi-hole over the past hour or so.
Any ideas what went wrong with the install?
$ pihole -v
Pi-hole version is v3.3.1 (Latest: v3.3.1)
AdminLTE version is v3.3 (Latest: v3.3)
FTL version is v3.0 (Latest: v3.0)
Pi-Hole Dashboard UI showing graphs
PI-Hole Query Log showing results
Graphs on Dashboard spin continuously
Query Log shows "Processing..." continuously
iaf5zwsgih
