Pi-Hole in VPS with cPanel
I have installed pihole in a vps with cPanel alreadly installed.. i try to skip php-cli because block the install and seems to work the web panel. but now the problem is the dns
In web panel the FTL seems to be online and pihole too is working with the api. but when i try to use the dns.. ads are not blocking and pihole is not receveing the data.
gq0k7xsu4k
A few problems noted in your debug lug.
These domains should have been filtered by Pi-Hole and 0.0.0.0 returned as the IP address:
[✓] ajakbytak.pl is 94.23.102.49 via localhost (127.0.0.1)
[✓] ajakbytak.pl is 94.23.102.49 via Pi-hole (173.249.49.178)
piHole-FTL is not running
[✗] dnsmasq daemon is unknown
[✓] lighttpd daemon is active
[✗] pihole-FTL daemon is inactive
You also have three IP addresses tied to your host platform network interface, one is in the range 173.248.49.xxx and the other two are on range 207.180.xxx.xxx.
   173.249.49.178/24 does not match the IP found in /etc/pihole/setupVars.conf
What is the output/result of the following command from the Pi-Hole host platform terminal:
