Hi all,
Amateur here.
I have just uninstalled pinhole from my home server (Ubuntu 16) as I already have an instance of Nextcloud installed on it and there was a conflict over Port 80. Nextcloud is running on Apache and is installed into /var/www/html/ and configured for access outside my network at mydomain.com. I have certbot/letsencrypt forcing all http://mydomain.com requests to go to https://mydomain.com
So, can I install pinhole somewhere other than the default /var/www/html/ and how do I go about managing the conflict over Port 80.
On a related note I've been reading about the need for a VPN to enable safe access to my pinhole instance from outside my network. So two questions about this;
- Will having a vpn installed interfere with my instance of Nextcloud?
- Will having a vpn installed interfere with my instance of Plex (which runs on a separate machine to Nextcloud)?
Thank you
jonr
