Pi-hole in Asustor doesn't restart
Hi
I use my pi-hole installation on NAS Asutor. I followed a guide on youtube with portainer.io
It works but when the NAS daily reboot Pihole is stopped while other container in portainer.io works.
The restart policies is in unless stopped mode as the tutorial suggest.
Also other container works with this mode of restart
Can u help me?
Thanks
Why is this rebooting daily?
Because every night the nas switch off to save energy and boot in the morning
You should not have Pi-hole running on a device that is not on
24/7.
so, there isn't solution? thanks
There may be a solution, but I don't have one. I don't use that software or equipment. Perhaps another user has some experience with this setup.
