Pi-Hole impact on emails
The issue I am facing:
Since installing an RPi hosted Pi-hole Ive noticed emails do not display pictures with associated links that can get me to the website. I whitelisted the domain for the linked site, which worked only once. I like everything the Pi-Hole is doing, but don’t want it to filter my emails or associated links, and when I whitelist a link, I need it to work all the time thereafter.
Details about my system:
RPi 3 hosting Pi-Hole
Just white lists.
Thanks,
Bob
These tools can help you determine which domains are being blocked that interfere with your content:
What OS is the client on which you are viewing emails running? MacOS has some particular settings to get emails to load.
Edit:
Tools > Generate Debug Log
Had a similar issue on my Apple devices through Pihole. Are you seeing this issue on Apple devices?
Mine was resolved I think by using the information here: BUG - IOS15/MacOS Monterey - Apple Mail Security 'your network settings prevent content from being loaded privately' - Help - Pi-hole Userspace
Specifically, I set BLOCK_ICLOUD_PR=false, and it worked for my situation.
