Pi-Hole GUI is unreachable
Hello, I’ve recently run into a problem where I can no longer access the GUI of my Pi-hole installation; I get the error message ERR_CONNECTION_REFUSED in Edge.
Restarting the Pi didn't help either. Pi-hole seems to be continuing to function normally.
https://tricorder.pi-hole.net/BzizyzDt/
Whats output for below three?
sudo pihole-FTL --config webserver.port
sudo ss -nltup | grep 'Netid\|pihole'
sudo nft list ruleset
And which URL is used in the browser to access Pi-hole?
Your debug log shows Pi-hole web server is using ports 8080 and 443.
Which address are you using exactly?
Can you access using these URLs? Or do you see the error?
