Pi-hole FTL v6.6, Web v6.5 and Core v6.4.1 Released!
Originally published at: https://pi-hole.net/blog/2026/04/03/pi-hole-ftl-v6-6-web-v6-5-and-core-v6-4-1-released/
As always, please read through the changelogs before updating with pihole -up
Don’t forget, you can use Teleporter to export your configuration. It can be found under the settings menu of the web interface or on the command line with pihole-FTL --teleporter
This release has also been tagged on Docker as 2026.04.0
Highlights
Security
Thank you to andrejtomci for responsibly disclosing multiple web interface vulnerabilities covering a range of XSS and HTML injection attack vectors.
Thank you to smittix for responsibly disclosing a local privilege escalation vulnerability in the Core component, where /etc/pihole/versions could be sourced by root-run Pi-hole scripts, allowing code execution as root in a post-compromise scenario. This has been fixed by replacing the source call with a safe parser that only assigns known keys with validated values.
Thank you to mzalzahrani for responsibly disclosing an authorization bypass in FTL, where CLI API sessions (intended to be read-only) were able to import Teleporter archives via /api/teleporter, bypassing the restrictions correctly enforced on /api/config. This has been fixed by applying the same CLI session check to the Teleporter import endpoint.
Thank you to T0X1Cx for responsibly disclosing a newline injection vulnerability in FTL, where several configuration parameters — including dns.upstreams, dns.hostRecord, dns.cnameRecords, dhcp.leaseTime, and dhcp.hosts — lacked validation against newline characters, allowing an authenticated attacker to inject arbitrary dnsmasq configuration directives. This has been fixed by adding newline validation to the affected config items.
Full details for all advisories can be found at the following links:
No More DNS Interruptions During Gravity Updates
FTL will now wait for a running pihole -g to finish before restarting, rather than potentially cutting it short and leaving your Pi-hole unable to serve DNS in the interim. This has been a long-standing edge case — it’s now properly handled. (FTL #2419)
MAC Address Name Resolution Control
A new resolver.macNames config option lets you control whether FTL attempts to resolve hostnames via MAC addresses. Useful if you’re running a network setup where clients aren’t all on the same Layer 2 segment and this behaviour was causing issues. (FTL #2790)
Other notable fixes
  • Query log showing millions of pages? A subtle integer underflow could cause the query counter to wrap to ~1.84×10¹⁹, making the log appear to have an absurd number of pages. Fixed. (FTL #2815)
  • Rate-limited queries inflating client counts — The “Top Clients” counter was being incremented before the rate limiter could reject a query, leading to inflated numbers. Fixed. (FTL #2814)
  • overTime graphs incorrect with database.DBimport = false — Garbage collection would never run in this configuration, causing memory to grow unboundedly and overTime data to be wrong. Fixed. (FTL #2788)
FTL v6.6
What’s Changed
New Contributors
Full Changelogv6.5…v6.6
Core v6.4.1
What’s Changed
New Contributors
Full Changelogv6.4…v6.4.1
Web v6.5
What’s Changed
New Contributors
Full Changelogv6.4.1…v6.5
