Pi-hole FTL v6.3, Web v6.3 and Core v6.2 Released!
Originally published at: https://pi-hole.net/blog/2025/10/25/pi-hole-ftl-v6-3-web-v6-3-and-core-v6-2-released/
As always, please read through the changelogs before updating with pihole -up
Don’t forget, you can use Teleporter to export your configuration. It can be found under the settings menu of the web interface or on the command line with pihole-FTL --teleporter
This release has also been tagged on Docker as 2025.10.0
Highlights
Security & TLS Enhancements
Shorter validity for self-signed TLS certificate (#2463) – The default validity period for self-signed TLS certificates has been reduced, aligning with modern security best practices and ensuring compatibility with Apple devices. To compensate for the shorter validity, automatic renewal has been implemented. Certificates now default to a 47-day validity period (configurable via webserver.tls.validity) and automatically renew when nearing expiration.
Improved Content Security Policy (#2575) – Improved default CSP headers provide better protection against XSS attacks while maintaining functionality.
Security Advisories:
Thank you to the folks who responsibly disclosed potential vulnerabilities since our last realease. Details of which can be read at the following links:
Network & DNS Improvements
Smart Interface Detection (#2456#2607) – FTL now automatically detects the appropriate DNS interface when dns.interface is empty in pihole.toml, eliminating manual configuration in most scenarios.
Netlink ARP Cache Handling (#2600) – Replaced external ip neigh show calls with internal netlink-based communication, dramatically improving performance and reducing resource usage. This addresses “database locked” issues seen in some environments.
Special Domain Handling (#2474) – Added support for .internal domain blocking (following RFC draft-davies-internal-tld-03), preventing these queries from being sent to upstream DNS servers while still allowing local resolution.
DNS Localization (#2524) – New dns.localise configuration option provides better control over DNS query handling.
IPv6 DHCP Support (#2554) – Enhanced the DHCP API to properly support IPv6 addresses and configurations.
Platform & Installation
Alpine Linux Support (pi-hole/pi-hole#6275) – Full native support for Alpine Linux has been added, including proper package management with apk, OpenRC init system support, and comprehensive testing. This expands Pi-hole’s reach to lightweight container environments and minimal installations.
User Interface & Experience
CLI Autocomplete (#2593pi-hole/pi-hole#6376) – Added bash-style completion support for pihole-FTL commands, making configuration much more user-friendly. Tab completion works for the entire --config path and suggests appropriate values.
Web Interface Improvements (web#3530web#3551web#3533web#3592FTL#2645FTL#2647FTL#2644web#3622) – Many small improvements: better visualization of DNS metrics, improved query log handling, enhanced gravity output with colors, refined button styling for blocked/allowed domain actions, improved load average detection and better system information gathering.
Configuration & Management
Advanced Web Server Options (#2635) – New webserver.advancedOpts configuration for fine-tuning web server behavior.
Enhanced API Endpoints (#2530#2632#2466) – Multiple API improvements including better error handling, optional restart parameters, and enhanced response formatting.
Web documentation for the config file – https://docs.pi-hole.net/ftldns/configfile/ – we have added some automation and a Python script to parse the latest pihole-FTL config file and to keep the documentation up to date on the web
Performance & Reliability
Updated Core Components (#2544#2576#2592#2570#2587#2603#2614#2621#2579):
  • SQLite3 updated to 3.50.4 for better database performance
  • dnsmasq updated to v2.92test21 with latest fixes
  • CivetWeb updated for improved web server functionality
  • Migrate TOML library to tomlc17 (tomlc99 has been marked as deprecated)
Memory Management (#2617) – Improved memory handling throughout the codebase to reduce resource usage and improve stability.
Database Resilience (#2605#2602#2646) – Enhanced gravity database handling with custom SQLite busy callbacks and better error recovery.
Bug Fixes & Stability
  • Fixed PTR query handling for .localhost domains (#2517)
  • Resolved DHCP string processing issues (#2519)
  • Fixed cache-optimizer query display in logs (#2619)
  • Improved NTP IPv6 crash handling (#2569)
  • Better foreign fork PR handling in CI (#2543)
  • Enhanced debug output and logging throughout (#2594)
Diagnostics
Improved Debug Output (#2600#2594) – More comprehensive debug information across networking, ARP processing, and system diagnostics.
Full Release Notes can be found below.
FTL v6.3
What’s Changed
New Contributors
Full Changeloghttps://github.com/pi-hole/FTL/compare/v6.2.3…v6.3
Core v6.2
What’s Changed
New Contributors
Full Changeloghttps://github.com/pi-hole/pi-hole/compare/v6.1.4…v6.2
Web v6.3
What’s Changed
New Contributors
Full Changeloghttps://github.com/pi-hole/web/compare/v6.2.1…v6.3
