Originally published at: Pi-hole FTL v6.2.2 Released – Pi-hole
Following on from our previous post, we have now released FTL v6.2.2, which contains fixes for some underlying bugs in dnsmasq that should now resolve the majority of cases where we have seen crashes. We have also downgraded the embedded version of SQLite from 3.50.0, as this was also causing issues.
Full details and converation around the issues can be found in pi-hole/FTL#2473
If you had switched to FTL v6.1 following the previous post, you may now switch back the released version pihole checkout ftl master should get you to v6.2.2
There are still a couple of outliers (pi-hole/FTL#2494, and pi-hole/FTL#2496) – though there is a fix on the FTL branch fix/filter_servers which should resolve those, though it is pending feedback. If you find that 6.2.2 still crashes for you, you are invited to try above branch with pihole checkout ftl fix/filter_servers and provide feedback on the above mentioned issues, or via our Discourse forum.
FTL Changes
This release addresses crashes reported in #2473 #2475 #2481 and friends.
What’s Changed
- Update build containers to Alpine 3.22 by @DL6ER in #2477
- Update dnsmasq to 2.92test11(-1) by @DL6ER in #2486
- Update dnsmasq to 2.92test11 by @DL6ER in #2489
- Revert the SQLite update to 3.50.0 as it is causing crashes for users by @DL6ER in #2488
- Update Lua to 5.4.8 (bugfix) by @DL6ER in #2491
- Fix typos in misc config settings by @rrobgill in #2485
- Display invalid character and offset correctly in hostname diagnosis by @rrobgill in #2484
Full Changelog: v6.2...v6.2.2
Join the Community
Pi-hole thrives thanks to our vibrant and supportive community. Whether you’re looking to share your experience, get advice, or stay informed about the latest updates, there’s a place for you. Join the conversation on our official forum or connect with fellow users on our subreddit. We look forward to welcoming you!
Thank You for Your Support
We want to express our heartfelt thanks to everyone who has supported Pi-hole throughout the years.
Your community contributions and donations are the lifeblood of this project, allowing us to maintain and continually improve Pi-hole while keeping it free for everyone. If you’d like to contribute to our ongoing efforts, please consider donating through our official donation page. Every contribution, big or small, makes a significant difference in helping us deliver the best project that we can.
Thank you for being part of the Pi-hole community!
