Originally published at: https://pi-hole.net/2021/10/23/pi-hole-ftl-v5-11-web-v5-8-and-core-v5-6-released/
As always, please read through the changelog before updating with pihole -up. (A new tag for docker image will arrive shortly.)
Pi-hole FTL changes:
- Prevent race collisions when parsing FTL config file #1222
- Fix incorrect response times for complex CNAMEs #1213
- Improve CI tests #1212
- Ensure compatibility with alpine 3.13+ #1210
- Support dynamic linking as fallback #1204 (thanks @pemensik)
- Add
PIHOLE_PTR=HOSTNAMEFQDNoption #1202 - Tweak rate-limiting #1199
- Improve interface detection #1198
- Fix rare crashes when rate-limiting happens before queries are blocked #1197
- Fix network byte order confusion in local lookups #1196
- Fix deep CNAME inspection #1192
Full Changelog: pi-hole/FTL@v5.10.2...v5.11
Pi-hole Core Changes:
- List fix: no reload #3981 by @andras-tim
- Consequently use defined file path variables #4105 by @MichaIng
- Remove obsolete DEB package name checks #4106 by @MichaIng
- add –no-rebase to the git pull command(s) to squelch hint message in newer versions of git (#4226) by @PromoFaux)
- Add ca-certificates to INSTALLER_DEPS #4343 by @yubiuser
- Remove netcat from dependencies (#4346) by @yubiuser
- Do not export DNS_FQDN_REQUIRED and DNS_BOGUS_PRIV unconditionally #4354 by @yubiuser
- Do not account for refactor anymore (#4355) by @yubiuser
- Do not let the user select if they want to blocking via IPv4 and/or IPv6 #4357 by @yubiuser
- Install script comment tweaks (#4361) by @PromoFaux
- Remove unused wildcard_regex_converter.sh (#4369) by @yubiuser
- Remove .idea/ #4373 by @friederbluemle
- Set file permission for querie database in pihole-FTL.service #4328 by @yubiuser
- Tweak final whiptail dialog #4321 by @PromoFaux
- Companion to pi-hole/AdminLTE#1231 #4375 by @PromoFaux
- Simplify vw_adlist #4379 by @yubiuser
- Make debug log file size human readable #4350 by @yubiuser
- Update upstream DNS server capability descriptions #4363 by @xanoni
- Include df -h in debug log #4380 (by @yubiuser)
- Fix PHP8.0 detection #4383 by @MichaIng
- Tweak local DNS record and CNAME #4384 by @yubiuser
- update tests: remove fedora 32, add fedora 34 #4403 by @bcambl
Full Changelog: pi-hole/pi-hole@v5.5...v5.6
Pi-hole Web changes:
- Dashboard icons – send to back and fixing position when scaled up #1915 by @rdwebdesign
- Unescape German umlauts #1914 by @yubiuser
- Add note to query log that pi.hole queries are not logged #1913 by @yubiuser
- Do not default true for unset variables DNS_FQDN_REQUIRED and DNS_BOGUS_PRIV #1909 by @yubiuser
- Background colors on Query log + striped table #1916 by @rdwebdesign
- fix: row background colors in query log #1906 by @lionralfs
- Make entire Forgot Password box header clickable #1917 by @davidjb
- #1777 “Remember me for 7 days” doesn’t work if you log in from Recent Queries #1870 by @chrismiceli
- Handle empty “” domain in query top list correctly #1790 by @yubiuser
- Modal-Dialog for Teleporter-import #1231 by @Th3M3
- Suppress empty lines during teleporter import #1921 by @yubiuser
- Do not try to resolve hostname of clients in long-term data #1931 by @yubiuser
- Add delete button to the network table to allow deleting individual entries #1924 by @yubiuser
- Do not restart for every item during Teleporter import of Local DNS record or CNAME #1925 by @yubiuser
- Display Docker Tag in footer if the PIHOLE_DOCKER_TAG environment variable is detected #1933 by @PromoFaux
- Set font’s color in teleporter iframe (fix for #1923) #1934 by @PromoFaux
- Prevent possible XSS attack vector on add_client GHSA-mhr8-7rvg-8r43 thanks to @stypr and @rpunnett for reporting
Full Changelog: pi-hole/AdminLTE@v5.7...v5.8
