I have a recurring issue where Pi-hole FTL suddenly stops applying my custom dnsmasq rules from /etc/dnsmasq.d/.
Setup:
Pi-hole with FTL
Custom dnsmasq configuration in
/etc/dnsmasq.d/ -
misc.etc_dnsmasq_d = true
Example rule:
/etc/dnsmasq.d/20-npmplus.conf
address=/*.mydomain.com/10.10.60.10
This configuration has been working for months.
Expected behavior:
unraid-server.mydomain.com
→ 10.10.60.10
But randomly the rule stops being applied. The file is still present and the configuration still shows:
However, queries suddenly return the public DNS answer instead:
→ ISP WAN
The issue affects internal split DNS. In my case this breaks WireGuard access because clients resolve the public address and traffic goes through NAT instead of directly to the internal service.
The fix is always the same:
sudo systemctl restart pihole-FTL
After restarting FTL, the rule immediately works again:
dig @10.10.100.50 unraid-server.mydomain.com
ANSWER:
10.10.60.10
This has happened twice now. The first time I also fixed it by restarting/reloading FTL.
I also noticed that:
pihole-FTL dnsmasq-test
fails with:
dnsmasq: cannot read /etc/pihole/dnsmasq.conf: Permission denied
Segmentation fault
(not sure if related).
Could this be an FTL reload/state issue where dnsmasq.d rules remain on disk but are no longer active until FTL is restarted?
