Hardware: Raspberry Pi 4
OS: Debian 11 Bullseye 64-bit
Pi-hole v5.8.1
AdminLTE v5.10.1
FTL 5.13
To my knowledge Pi-hole should not forward lb._dns-sd._udp.0.0.0.10.in-addr.arpa
PTR queries. After reading /etc/dnsmasq.d/06-rfc6761.conf
which states that RFC 6761 requests that PTR requests for private IP range should not be forwarded and that the dnsmasq option bogus-priv
provides that. Which the dnsmasq man page is consistent with and states:
Bogus private reverse lookups. All reverse lookups for private IP ranges (ie 192.168.x.x, etc) which are not found in /etc/hosts or the DHCP leases file are answered with "no such domain" rather than being forwarded upstream. The set of prefixes affected is the list given in RFC6303, for IPv4 and IPv6.
As far as I can tell both RFC's are similar.
Pi-hole's logs show about 167 PTR queries per day being forwarded to upstream DNS.
13:33:09: query[PTR] lb._dns-sd._udp.0.0.0.10.in-addr.arpa from 10.0.0.55 13:33:09: forwarded lb._dns-sd._udp.0.0.0.10.in-addr.arpa to 2606:4700:4700::1001 13:33:09: reply lb._dns-sd._udp.0.0.0.10.in-addr.arpa is NXDOMAIN 13:33:29: query[PTR] lb._dns-sd._udp.0.0.0.10.in-addr.arpa from 10.0.0.53 13:33:29: forwarded lb._dns-sd._udp.0.0.0.10.in-addr.arpa to 2606:4700:4700::1001 13:33:29: reply lb._dns-sd._udp.0.0.0.10.in-addr.arpa is NXDOMAIN 13:34:21: query[PTR] lb._dns-sd._udp.0.0.0.10.in-addr.arpa from 10.0.0.54 13:34:21: forwarded lb._dns-sd._udp.0.0.0.10.in-addr.arpa to 2606:4700:4700::1001 13:34:21: reply lb._dns-sd._udp.0.0.0.10.in-addr.arpa is NXDOMAIN 13:34:46: query[PTR] lb._dns-sd._udp.0.0.0.10.in-addr.arpa from 10.0.0.51 13:34:46: forwarded lb._dns-sd._udp.0.0.0.10.in-addr.arpa to 2606:4700:4700::1001 13:34:46: reply lb._dns-sd._udp.0.0.0.10.in-addr.arpa is NXDOMAIN
Pi-hole is not DHCP, so I don't have a leases file, but here is my hosts file:
127.0.0.1 localhost ::1 localhost ip6-localhost ip6-loopback ff02::1 ip6-allnodes ff02::2 ip6-allrouters 127.0.1.1 pihole # DNS 1.1.1.1 v4-1 1.0.0.1 v4-2 2606:4700:4700::1111 v6-1 2606:4700:4700::1001 v6-2
I do have a 10-custom.conf
in dnsmasq.d
for hostname mapping. It follows dnsmasq's host-record
option for hostname resolution
host-record=hostname,10.X.X.X,2603:8000:XXXX:XXXX::XXXX
Is there something I'm missing in the RFC's or am I correct in expecting Pi-hole to automatically return NXDOMAIN for those queries?
https://tricorder.pi-hole.net/v0txdKPU/
