i ran nslookup flurry.com in my computer that has the dns configured and it still gave me the normal IP. running pi.hole is not available since the machine is a VPS and is not at my local LAN.
also, nginx does nothing on my pihole server since it's running at port 80 and lighttpd at port 8088.
the public IPs are basically mine and my other routers and all that because its a VPS not in LAN.
Don't open port 53 to the world. This creates an open resolver and we do not provide support for users that chose to run with that kind of configuration.
i was checking here and i see that centos and localhost are actually getting blocked from accessing some domains. this is what i expected to happen normally in my windows pc.
it shows in the web panel that it blocked 7 requests, but in my pc it still doesn't work as expected.
so, i don't really know what happened, but after the 3rd reinstall i did, everything started working just fine....
i think that i just changed from cloudflare dns to google dns and now it works correctly
