according to Ultimate Pi-Hole Raspberry Pi Setup: Faster Internet in 15 min | SimpleHomelab,
i should see a screen with 'installation complete' and an web admin password
[i] Existing PHP installation detected : PHP version 5.6.40-0+deb8u4
[✓] Disk space check
[✓] Checking apt-get for upgraded packages... 9 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✓] Checking for apt-utils
[✓] Checking for dialog
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[i] Using Cloudflare
[i] Static IP already configured
[i] Found IPv6 ULA address, using it for blocking IPv6 ads
[i] IPv4 address: 10.0.0.63/24
[i] IPv6 address: fd2f:52eb:a83a:0:8f14:504a:9fe7:3c7d
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[✓] Check for existing repository in /etc/.pihole
[✓] Update repo in /etc/.pihole
[✓] Check for existing repository in /var/www/html/admin
[✓] Update repo in /var/www/html/admin
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[i] Checking for resolvconf (will be installed)
[✓] Checking for lighttpd
[✓] Checking for php5-common
[✓] Checking for php5-cgi
[✓] Checking for php5-sqlite
and then I'm getting thrown back to a prompt
since pi-hole does not install, I can not give a debug token.
