The issue I am facing:
Pi-hole.docker works fine on my Unraid server. After a couple of days I can't reach the community apps inside Unraid (the host).
The message I got is:
Download of appfeed failed.
Community Applications requires your server to have internet access. The most common cause of this failure is a failure to resolve DNS addresses. You can try and reset your modem and router to fix this issue, or set static DNS addresses (Settings - Network Settings) of 208.67.222.222 and 208.67.220.220 and try again.
Alternatively, there is also a chance that the server handling the application feed is temporarily down. See also this post for more information
Last JSON error Recorded: Syntax error
I'm not sure where I can start looking where my mistake is.
All other devices works great.
Details about my system:
Unraid
I only change the DNS Server in my router FritzBox 7590.
