Pi-Hole Docker Logs to Graylog
I'm trying to forward my Pi-Hole logs to Graylog but I'm having trouble finding the DNS query logs location. I'm using the following docker-compose " Docker - Pi-hole documentation " with the "./etc-dnsmasq.d:/etc/dnsmasq.d" line uncommented but I'm not seeing any logs in that location. Where are the DNS queries stored or is there a different compose file I should be using?
If you want the raw DNS logs, they are stored in/var/log/pihole/pihole.log, inside the container.
If you want the data showed in the Query Log page, it is stored in /etc/pihole/pihole-FTL.db (this is a SQLite database).
This has nothing to do with logs.
This path is used only when a user wants to add advanced configuration files to dnsmasq (and the misc.etc_dnsmasq_d is enabled). You don't need this.
Thank you so much for the response, I greatly appreciate it. It doesn't sound like I'll be able to forward those logs to Graylog after all. Bummer.
If you only care about the .log files, you can try to create a volume for the logs:
    volumes:
      # For persisting Pi-hole's databases and common configuration file
      - './etc-pihole:/etc/pihole'
      # Pi-hole Logs
      - 'path_on_the_host/for/your/logs:/var/log/pihole'
Then you can access the logs on the host machine: path_on_the_host/for/your/logs/pihole.log. Just remember to replace "path_on_the_host/for/your/logs" with a real path.
