Hello,
I have a problem with my Pi-hole (which im running on docker).
I tried out if Pi-hole works, and everything seems alright, but then I found out that there are no domains in the blacklist, its completely empty!
So I tried to reconfigure it.
After running the command: sudo docker exec -it pihole pihole -r
and after running it I got the Error: Neither IPv4 or IPv6 selected
Can someone help me with that?
Thanks
