Hi All,
I recently bought a Raspberry PI 5 to connect with my TV to stream movies using just the browser in Raspberry OS.
I also wanted to install Pi-Hole on the same Raspberry PI 5.
I managed to successfully install Pi-Hole but I’m running into some problems.
When accessing the Adblock testeron the browser of my Raspberry PI it shows a score near to 100 indicating that it is working locally.
I can also access the Pi-Hole admin panel on my Raspberry PI.
To issue I have is making Pi-Hole work on all my devices on my network.
I changed the “/etc/dhcpcd.conf” file on my Raspberry PI to set a static IP address using the following lines:
“interface eth0
static ip_address=192.168.68.14/24
static routers=192.168.68.1
static domain_name_servers=192.168.0.1 1.1.1.1”
In my Deco settings I set the primary DNS under DHCP Server to 192.168.68.14 and also the secondary (How to use Pi-Hole DNS Server on TP-Link routers)
When I now run the following command “hostname -I” on my Raspberry PI I see 2 IP addresses, one of them being 192.168.68.14 and a complete other one (192.168.0.234).
Accessing 192.168.68.14 on the browser of a different PC on that network doesn’t work.
FYI: My Raspberry PI is connected with Ethernet and my home network is a Mesh WiFi network (Deco X50).
After hours of searching online I can’t find what I’m doing wrong, all help is welcome.
Thanks a lot for the help!
