[working dns
-operating system
-hardware]
[tried to update my pi hole using pihole -up. It failed saying it can't verify the os. Since then DNS and FTL refuse to start and I can't reach anything on the internet.]
Sep 27 09:22:16 Pi_Hole pihole-FTL[1541]: /usr/bin/pihole-FTL: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.28' not found (required by /usr/bin/pihole-FTL)
How did you upgrade your system?
Did you install a fresh OS or did you tried an in-place upgrade?
I did an inplace upgrade. I was able to fix the glibc by updating it, but now I am having a different issue with not maintaining my static IP. I created a new topic for that.
They tend to be complicated and usually leads to problems with missing libraries or wrong versions, specially in cases like this. You went from Debian 9 to Debian 11.
