instead of lighttpd
[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
-operating system
-hardware]
I followed this guide to configure pi-hole in openwrt but its not working Correct Way to Set DNS Server - #24 by willowen100 - Network and Wireless Configuration - OpenWrt Forum
[Replace this text with the debug token provided from running pihole -d
(or running the debug script through the web interface]
