PI HOLE DNS does not route local records
I would like to access my services using the domain name instead of the IP address
My Pi-hole is not working correctly. I have tried many solutions, but nothing seems to work. I am using Pi-hole for both DNS and DHCP. When I try to use nslookup, it returns a "non-existent domain" error.
https://tricorder.pi-hole.net/wNPOUJjV/
Please share the output of the following commands, run from the client that can't resolve a domain:
nslookup pi.hole
nslookup <your.domain>
nslookup <your.domain> 192.168.178.240
where you substitute <your.domain> with your domain name.
*** bck-s-pihole wurde von fritz.box nicht gefunden: Non-existent domain.
nslookup bck-s-pihole
Server:  fritz.box
Address:  fd00::<redacted>b5
nslookup bck-s-gitlab
Server:  fritz.box
*** bck-s-gitlab wurde von fritz.box nicht gefunden: Non-existent domain.
nslookup bck-s-gitlab 192.168.178.240
Server:  pi.hole
Address:  192.168.178.240
Address:  192.168.178.7
Your router is advertising its own IPv6 ULA as DNS server, allowing clients to bypass your Pi-hole completely.
Your Pi-hole has to be the sole DNS server for your clients.
Current FritzBox models should support deactivating IPv6 DNS servers via Home Network|Network|Network Settings|IP Addresses|IPv6 Settings.
Try:
a. Untick Also announce DNSv6 server via router advertisement (RFC 5006).
b. Tick Disable DHCPv6 server in the FRITZ!Box for the home network and
b.1. choose There are no other DHCPv6 servers for the home network.
This will have clients construct their IPv6 addresses via auto-configuration (SLAAC) exclusively, and will leave them with just an IPv4 address for DNS.
The one potential drawback would be that IPv6-only clients would have no means of DNS resolution. IPv4-only as well as dual-stack clients would still be fully satisfied with an IPv4 DNS server.
I've currently lost the connection to our WireGuard network at the church and will be working to resolve the issue.
I'll get back to you once the connection is restored.
Thank you for your understanding!
