Hi I am new here
When assign a Static Dynamic lease from a Dynamic allocated IP I expected the Dynamic IP lease to be released. e.g. 192.168.1.120 Dynamic > Static IP assigned 192.168.1.4 then the Dynamic IP should no longer be seen
Dynamic assigned IP address remains under Dynamic after a Static IP has been assigned. Question is why or when will the Dynamic assigned IP go away?
[https://tricorder.pi-hole.net/ghmgsdmgdd!]
Steen
Have you released the DHCP lease on the device that had the address set?
Hey Dan,
Only been able to do a few by power of and on, as several at devices I cannot log into, but even having done a ipconfig /release and /renew the "old dynamic IP is still there", can be I am doing something wrong...
Does the DHCP lease page on the admin interface show entries with the same MAC address in both the active and static sections?
Yes, but perhaps I have to wait until the lease time is up, I had set to 24 will change to less.
The leases are actually stored in a file, I think they can be removed and pihole-FTL restarted, but I don't remember offhand the file name or location. If this is still an issue after the lease lifetime is over we can dig some more and find the way to manually edit the leases.
Leases are stored in below file (checked just now):
sudo nano /etc/pihole/dhcp.leases
To restart pihole-FTL:
sudo service pihole-FTL restart
Hi Dan Thanks
Hi DeHakkelaar Thanks
Sorry for slow response had to help the boss in the house
Shall try the above and give feeedback
Hey Dan and DeHakkelaar,
Got it sorted out, first I powered of all devices and then deleted the entries in the dhcp.leases file, then powered on the devices and restarted pihole-FTL
Thnaks for the help
