Hi Pi-hole community! I'm currently dealing with a bizarre issue where nothing is being displayed in my dashboard, and I was wondering if anyone here might be able to diagnose and solve the problem. I've searched far and wide for a solution but none of the troubleshooting suggestions have worked. If anyone here can help, I'd greatly appreciate it. Alright, here goes!
Dashboard displays metrics and graphs correctly instead of null values and spinning arrows
Have tried running a reconfiguration (pihole -r) where logging was enabled and all recommended settings were used; no luck
Pihole status indicates DNS service is running and Pi-hole blocking is enabled
Running pihole -t indicates stuff is happening
Static IP of [192.168.1.8] assigned to PiHole, which matches the IP address in the admin page's Settings page
Issue is persistent across multiple clients and browsers, including a 2013 Macbook Pro running Catalina and using Chrome and Safari, a PC running Windows 10 and using Chrome and Edge, a 2018 Macbook Air running High Sierra and using Chrome and Safari, and iOS devices running iOS12 and iOS13.
Open the network tab in the dev tools, select the JS filter, and refresh the page. Share a screenshot of the dev tools and check if any of the requests failed.
For some reason, a core library (jQuery) is not being loaded. Maybe the request for the code is failing, or the response is empty.
With this issue being persistent across multiple machines, different browsers, and different operating systems, it's gotta be something in the pi-hole setup, right?
Please check the "disable cache" button and try again. The issue could be caused by many things, and this will help find that cause by determining why the library is not loading.
When clicking jquery.min.js, jquery-ui.min.js, and bootstrap.min.js, i get a "Nothing to preview" in the preview screen, as seen in the screenshot below:
