Pi Hole dashboard not coming up
I am running Pi Hole on Raspberry Pi 4. It was working perfectly. I tried to install Unbound. I thought I got it installed correctly. Now the dashboard is not accessible. I uninstalled Unbound, but that did not fix it. I am using Tailscale on my network (Synology NAS, etc.) So I tried installing Tailscale, but that made no difference.
The admin dashboard page is not coming up in the browser. I get a 403 error
pi hole version:
Core version is v6.0.4 (Latest: N/A)
Web version is v6.0.1 (Latest: N/A)
FTL version is v6.0.3 (Latest: N/A)
OS version:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="Debian -- User Support"
BUG_REPORT_URL="https://bugs.debian.org/"
When i try to hit the url http://<ip_address>/admin, I eventually get a 403 Forbidden error.
I have the token in a file. I am a hesitant to post it here because it contains sensitive information. Tell me which portion is needed to diagnosis the problem. I'll gladly post what is needed.
The token URL contains no sensitive information. The token leads to your unique debug log on our server, which is accessible for only 48 hours and only by 9 people on this planet.
Any sensitive information stays with your debug log and dies a natural death after 48 hours.
Just post the URL token here. Never post the full file.
Steps to generate a debug Token.
  • Execute pihole -d.
  • When Pi-hole asks you to upload the file, you answer "Y" (the file will be sent to a secure server).
  • Then you will receive a token like this: https://tricorder.pi-hole.net/Abc123yZ.
  • post only the token here.
Thanks for explain it to me. I have a question, should pihole -d require sudo? Because mine does require sudo.
I got this error when I tried to upload the pihole -d output:
* Error message: curl: (6) Could not resolve host: tricorder.pi-hole.net
[βœ—] There was an error uploading your debug log.
  • A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
OK. I turned off Tailscale and tried again. Here is my token:
https://tricorder.pi-hole.net/GeOOTXfz/
Yes, starting in V6.
Lighttpd is running on port 80, preventing FTL from binding to that port:
[βœ—] tcp:0.0.0.0:80 is in use by lighttpd (https://docs.pi-hole.net/main/prerequisites/#ports)
[βœ—] tcp:[::]:80 is in use by lighttpd (https://docs.pi-hole.net/main/prerequisites/#ports)
FTL is running on port 443, since that port is vacant. You can access your Pi-hole web admin GUI at the following URL:
https://192.168.1.253/admin
If you want FTL on port 80, stop and disable lighttpd and restart FTL.
You have FTL configured as follows in file /etc/pihole/pihole.toml - the default settings.
  # Ports to be used by the webserver.
  # Comma-separated list of ports to listen on. It is possible to specify an IP address
  # to bind to. In this case, an IP address and a colon must be prepended to the port
  # number. For example, to bind to the loopback interface on port 80 (IPv4) and to all
  # interfaces port 8080 (IPv4), use "127.0.0.1:80,8080". "[::]:80" can be used to
  # listen to IPv6 connections to port 80. IPv6 addresses of network interfaces can be
  # specified as well, e.g. "[::1]:80" for the IPv6 loopback interface. [::]:80 will
  # bind to port 80 IPv6 only.
  # In order to use port 80 for all interfaces, both IPv4 and IPv6, use either the
  # configuration "80,[::]:80" (create one socket for IPv4 and one for IPv6 only), or
  # "+80" (create one socket for both, IPv4 and IPv6). The '+' notation to use IPv4 and
  # IPv6 will only work if no network interface is specified. Depending on your
  # operating system version and IPv6 network environment, some configurations might not
  # work as expected, so you have to test to find the configuration most suitable for
  # your needs. In case "+80" does not work for your environment, you need to use
  # "80,[::]:80".
  # If the port is TLS/SSL, a letter 's' (secure) must be appended, for example,
  # "80,443s" will open port 80 and port 443, and connections on port 443 will be
  # encrypted. For non-encrypted ports, it is allowed to append letter 'r' (as in
  # redirect). Redirected ports will redirect all their traffic to the first configured
  # SSL port. For example, if webserver.port is "80r,443s", then all HTTP traffic coming
  # at port 80 will be redirected to HTTPS port 443.
  # When specifying 'o' (optional) behind a port, inability to use this port is not
  # considered an error. For instance, specifying "80o,8080o" will allow the webserver
  # to listen on either 80, 8080, both or even none of the two ports. This flag may be
  # combined with 'r' and 's' like "80or,443os,8080,4443s" (80 redirecting to SSL if
  # available, 443 encrypted if available, 8080 mandatory and unencrypted, 4443
  # mandatory and encrypted).
  # If this value is not set (empty string), the web server will not be started and,
  # hence, the API will not be available.
  # Possible values are:
  #     comma-separated list of <[ip_address:]port>
 port = "80o,443os,[::]:80o,[::]:443os"
You can also move FTL to another http port (8080, for example) if you intend to use lighttpd for other purposes.
Thanks for the detailed reply. It’s a little confusing to me. What is the best configuration?
We can't choose... this is a personal choice and it varies from user to user.
My suggestion is:
  • If you are not using lighttpd for other services, stop and disable lighttpd and restart FTL.
I understand. Thanks for all your help
