Originally published at: Pi-hole Core v6.1.3 Released β Pi-hole
This is a bugfix release for the core Pi-hole code.
Fixes
- Prevent gravity from failing due to an empty shell variable. #6191
This fixes a case where calls topihole -gfailed during list downloads. - Require privileged status (root or sudo) for all user calls to
pihole. #6312
This fixes cases where users are unable to change or update the admin password. - Exit installation if FTL binary can not be downloaded. #6316
Abort update if FTL branch does not exist. #6329
These fix cases where the installation did not fully complete or an update left the installation with mismatched binary and repository versions. Both fixes contributed by @MichaIng - Restore
pihole -qfunction. #6284
This fixes a case where running a query immediately failed with an error message for an unknown file.
Miscellaneous Fixes and Improvements
- Display output from FTL commands in color on the terminal. #6314
- Add note to final installation dialog box showing users where to find instructions for allowing a user to run Pi-hole commands without authentication. #6152
- Allow
pihole tailto search for strings beginning with the hyphen character. #6318 Contributed by @rrobgill - Do not update the package cache on updates. #6282
- Improve default route detection in debugging process. #6303 Contributed by @rrobgill
- Improve detecting loopback interfaces in the installer. #6269 Contributed by @deHakkelaar
