Pi-hole comes offline every night
Hi, may I please have some help on my pi-hole which loses connection virtually every night of late?
The debug token is kovu7hy2p3.
Thanks in advance
The only issue I see is that you might have configured Pi-hole initially on one interface but used the IP of another:
---= Checking IPv4 Stack
No IPv4 found on eth0
However, your DNS tests were successful. What are the symptoms when it disconnects? Are you unable to ping it, SSH, etc? Can you see flashing lights on its physical network interface?
Thanks for looking.
The pi is connected by wifi.
The symptoms are that I cannot ping nor SSH the pi on the fixed IP address. The light is definitely on the pi but not sure if the network light flashes on ping/SSH activity.
And other way around, if connect keyboard + screen, can you ping other devices on the network ?
The WiFi adapter might have went into sleep/power saving mode after inactivity during the night.
