Details: headless pihole cluster, primary on rpi pizero 2 W, secondary on rpi pizero 1 W, gravity-synced. Cloudflare for Families ipv4/6 upstream with DNSSEC enabled listening on eth0. No ipv4/6 DNS leaks, per a few websites. No other services running on either pizero.
The primary pihole is good. I recently reflashed primary with latest rasp pi os and reinstalled pihole. Not because of any os or pihole issues, but because I had tried to install and configure Openvpn after pi-hole while most tutorials describe installing Openvpn first. Idk what happened, I could connect remotely and use pihole, but it was not hiding my home ip. Trying to fix that I misconfigured routing tables with the help of ChatGPT and broke everything. We were both too stupid to fix them, and it became apparent the quickest fix was a complete reinstall then teleporter to upload settings. Anyway, I digress...
The secondary pihole may be acting up. It has significantly less traffic but also significantly less percentage of ads blocked lately. They are synced, as noted, almost 3M domains. I have checked the settings on both piholes and I think they are the same. It is working and blocking. But while primary pihole is blocking 15-25%, the secondary has been only 1-10% over the last 24 hours. Is this expected since all devices are pointing to primary pihole as their primary dns? Should I invert them on a few devices for more manual load-balancing?
Abouts hosts file: I have duplicated the /etc/hosts files on both piholes. Current method, I copy/paste or manually enter on each via console ssh sessions. I have checked that custom.lists are both blank or renamed on both because it seems that hosts file is preferred, and I don't think there are any other entries in dnsmasq.d interfering with hosts file. So... ipv6 is enabled on both. I know, not needed but our requests seem pretty evenly distributed between ip4/6. But this is where it gets weird for me again, even though host entries seem to be same on both, only the secondary pihole shows ipv6 addresses without host names in dashboard stats. Why would the primary dashboard have nice neat client stats all mapped to the hosts file while the secondary is a mess with a mix of 4/6 addreses?
Considering both of my "issues", disparate % ads blocked and host mapping, on what used to be a tighter pair of piholes... is it normal behaviour, stupid human error, or should I reinstall, maybe on new sd card? Maybe its fine...?
Should I upload logs?
Is there a tutorial on configuring OpenVPN AFTER pi-hole is installed? I need the vpn active for remote access. But I don't want to break my pihole again in the process.
Thanks in advance.
edit: I saw in another post to run:
nslookup flurry.com 192.168.0.30
nslookup flurry.com 192.168.0.40
I don't know what that does, or what it means, but all requests time out.
