Pi-hole causing "additional logon information may be required" message
Hi all,
after today update list Pi-Hole i hawe a same problem as users on reddit...
All my PC says:
https://www.reddit.com/r/raspberry_pi/comments/46gplq/pihole_causing_additional_logon_information_may/
https://snag.gy/6Iecol.jpg
I was deleting the cache. Restart PC and still the same :frowning:
You probably need to whitelist several Microsoft domains:
Thank you.
I found a mistake .. I had in the list of duplicate block list list .. ( Lists used to generate Pi-hole's Gravity)
(maybe improvements for the new version.)
It would not be possible to add a duplicate in COLLOR list.
Thank you annd have a nice day :slight_smile:
Had the same issue and decided to whitelist both domains : IPv4 and IPv6 variants are used by Windows (and some other devices which makes this a weird thing!) to check for connectivity!
I think one of the blacklist maintainers has decided to block them since today ?!
