Pi-hole broke weather.com
Just installed pi-hole a couple of hours ago, so far everything has been well, but just noticed one website is broken, weather.com - it doesn't allow to do a search for locations and doesn't display previous locations. It is broken on all of my computers, was working fine before the installation of pi-hole, albeit ridden with ads.
Use these tools to determine why your desired content does not load:
@och FWIW. I verified something similar with my Mac at this site with Pi-hole enabled. Looking at the Query Log, I found an entry that have been blocked via Gravity. It was mparticle.map.fastly.net. Once I whitelisted it, the site worked as expected.,
Thank you so much! That did the trick!
You're very welcome! I'm glad you got it worked out.
