Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
After update pi-hole from 4.x version to 5. Pihole starting blocks normal domains with gravity
for example:
Google mail stopped working (mail.gmail.com)
vk.com (russian social network)
mail.yandex.ru (one more mail web client)
https://tricorder.pi-hole.net/ta1a4gtzrr
jfb
June 4, 2020, 2:10am
2
Let's take a look at this one. What is the output of the following commands from the Pi terminal:
pihole -q vk.com
dig vk.com @127.0.0.1
sqlite3 /etc/pihole/gravity.db "SELECT address FROM adlist;"
jfb
June 4, 2020, 2:13am
3
If this is the domain you are using to access it, the domain does not exist:
dig mail.gmail.com
; <<>> DiG 9.11.5-P4-5.1+deb10u1-Raspbian <<>> mail.gmail.com
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 1656
;mail.gmail.com. IN A
;; Query time: 1 msec
;; WHEN: Wed Jun 03 21:11:58 CDT 2020
;; MSG SIZE rcvd: 43
Do you use pihole too?
root@raspberrypi:/etc/pihole# dig +short @8.8.8.8 mail.google.com
googlemail.l.google.com.
74.125.205.19
74.125.205.17
74.125.205.18
74.125.205.83
I found problems with vk.com and yandex.ru. Ty
What about mail.google.com?
jfb
June 4, 2020, 2:48am
6
JohnnyJO:
Yes.
JohnnyJO:
mail.google.com
This is not the same domain you posted earlier.
dig +short mail.google.com
172.217.8.165
O, sorry, my bad. All domains found in custom blocklist. Sorry for topic
jfb
June 4, 2020, 2:57am
8
You should get rid of these lists that are not supported by Pi-hole. They are not properly formatted and are causing your problems.
https://easylist-downloads.adblockplus.org/antiadblockfilters.txt
https://easylist-downloads.adblockplus.org/bitblock.txt
https://easylist-downloads.adblockplus.org/cntblock.txt
This list cannot be imported since it has an invalid character in the URL, and if it is already in your list it won't process properly.
https://easylist-downloads.adblockplus.org/ruadlist+easylist.txt
system
Closed
June 25, 2020, 3:10am
9
