Pi-hole beta occasionally gets "stuck" and stops responding to DNS requests
Pi-hole beta occasionally gets "stuck" and stops responding to DNS requests (that should be responded to). After a few seconds or minutes, things start working again without a need for further intervention.
The machine is a beefy quad core xeon running Ubuntu directly, so I feel like if this runs on a Pi, it should run great on this machine.
No freezes or stuck DNS queries.
Random and occasional "stuck" DNS. pihole -t shows nothing interesting while it is stuck, and continues on after it gets unstuck.
Bad tokens (most confident of the first one) taken while stuck:
y64sjicevo
3m94uezu92
Good token (no stuck):
fyjwj8u14e
Check /var/log/pihole.log and /var/log/pihole-FTL.log when it's stuck and not stuck. Also, are you able to SSH in while it's stuck?
I think /var/log/pihole.log is just the output of pihole -t, right? That also appears stuck when the DNS is stuck.
I can SSH no problem (can run commands remotely, etc) while it is stuck.
I can tail /var/log/pihole-FTL.log
but here is the current contents of that file:
cat /var/log/pihole-FTL.log
[2018-07-17 07:10:00.590] Notice: Increasing overTime struct size from 200 to 300 (2.74 MB)
[2018-07-17 12:53:24.708] Notice: Increasing queries struct size from 40000 to 50000 (3.39 MB)
[2018-07-17 19:41:08.259] Notice: Increasing queries struct size from 50000 to 60000 (4.04 MB)
[2018-07-17 21:47:28.887] Notice: Increasing domains struct size from 3000 to 4000 (4.08 MB)
When it is stuck, does the web interface work correctly?
No, it does not.
Try the FTL debugging instructions: Redirecting...
