I don't think my previous reply was accurate (working off mobile). The getOverTime message normally indicates that the time on the Pi was recently changed. I'll ask one of the developers to look at this.
journalctl -u systemd-timesyncd.service
-- Logs begin at Fri 2019-10-11 15:17:01 BST, end at Mon 2019-10-14 22:50:02 BST. --
Oct 11 15:17:14 raspberrypi systemd[1]: Starting Network Time Synchronization...
Oct 11 15:17:16 raspberrypi systemd-timesyncd[206]: System clock time unset or jumped backwards, restoring from recorded timestamp: Fri 2019-10-11 15:33:52 BST
Oct 11 15:33:52 raspberrypi systemd[1]: Started Network Time Synchronization.
Oct 13 23:27:44 raspberrypi systemd-timesyncd[206]: Synchronized to time server for the first time 203.95.213.129:123 (2.debian.pool.ntp.org).
`pi@raspberrypi:~ $ journalctl -u ntp`
BST, end at Mon 2019-10-14 23:00:02 BST. --
-- No entries --
pi@raspberrypi:~ $ timedatectl status
Local time: Mon 2019-10-14 23:29:04 BST
Universal time: Mon 2019-10-14 22:29:04 UTC
RTC time: n/a
Time zone: Europe/London (BST, +0100)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
Under ssh I reran raspi-config and reset the locale and then the timezone (No actual changes) then sudo reboot
Seems to be OK now, certainly no warnings of the getOverTimeID type.
